I need help using newly installed OpenFoam Package please?
Old   September 6, 2011, 16:49
Default I need help using newly installed OpenFoam Package please?
Estes is on a distinguished road
Hi I'm new to both Linux Ubuntu and OpenFOAM ( in fact its the only reason why Im having to use Linux). I just finished installing OpenFOAM and im in the general installation section page of OpenFOAM. I am currently trying to find the file $HOME/OpenFOAM directory in order to install a subdirectory <User>201 , but when I go on the Terminal and type in $HOME/OpenFOAM it says "No such file in directory".
I try to reinstall OpenFOAM from the very beginning, but it says:
Reading package lists... Done
Building dependency tree
Reading state information... Done
openfoam201 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded
Help! Why can't I find the OpenFOAM directory? How can I fix this?
Thanks
-Estes
Estes is offline   Reply With Quote
Old   September 7, 2011, 04:16
Retired Super Moderator
Bruno Santos
Greetings Estes and welcome to the forum!
I'm assuming you are following the instructions from here: http://www.openfoam.com/download/ubuntu.php
It's quite simple: just run the commands they show you. The text is simply a description of the steps themselves, while the commands do everything for you.
Best regards,
Bruno
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 11:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 12:46
