OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 |
December 25, 2010, 10:17 |
wenzhongqing
Rep Power: 15 |
When I command: source $HOME/.bashrc or source ~/.bashrc ,
bash: ./home/flakid/OpenFOAM/OpenFOAM-1.7.1/etc/bashrc: No such file or directory However bashrc exists there indeed, then I get into the dictionary etc/ and : source bashrc and :foam and: ./Allwmake the result: ./Allwmake: line 13: make: command not found ======================================== Start ThirdParty Allwmake ======================================== ======================================== Compile specific mpi libraries + cd openmpi-1.4.1 + make distclean + rm -rf /home/flakid/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/openmpi-1.4.1 + unset mpiWith + '[' -n '' ']' + ./configure --prefix=/home/flakid/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/openmpi-1.4.1 --disable-mpirun-prefix-by-default --disable-orterun-prefix-by-default --enable-shared --disable-static --disable-mpi-f77 --disable-mpi-f90 --disable-mpi-cxx --disable-mpi-profile checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... no checking how to create a ustar tar archive... gnutar ================================================== ========================== == Configuring Open MPI ================================================== ========================== *** Checking versions checking Open MPI version... 1.4.1 checking Open MPI release date... Jan 14, 2010 checking Open MPI Subversion repository version... r22421 checking Open Run-Time Environment version... 1.4.1 checking Open Run-Time Environment release date... Jan 14, 2010 checking Open Run-Time Environment Subversion repository version... r22421 checking Open Portable Access Layer version... 1.4.1 checking Open Portable Access Layer release date... Jan 14, 2010 checking Open Portable Access Layer Subversion repository version... r22421 *** Initialization, setup configure: builddir: /home/flakid/OpenFOAM/ThirdParty-1.7.1/openmpi-1.4.1 configure: srcdir: /home/flakid/OpenFOAM/ThirdParty-1.7.1/openmpi-1.4.1 checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu installing to directory "/home/flakid/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/openmpi-1.4.1" *** Configuration options checking whether to run code coverage... no checking whether to compile with branch probabilities... no checking whether to debug memory usage... no checking whether to profile memory usage... no checking if want developer-level compiler pickyness... no checking if want Fortran 90 bindings... no checking desired Fortran 90 bindings "size"... disabled (Fortran 90 bindings disabled) checking whether to enable PMPI... no checking if want C++ bindings... no checking if want MPI::SEEK_SET support... yes checking if want to enable weak symbol support... yes checking if want run-time MPI parameter checking... runtime checking if want to install OMPI header files... no checking if want pretty-print stacktrace... yes checking if peruse support is required... no checking max supported array dimension in F90 MPI bindings... 4 checking if pty support should be enabled... yes checking if user wants dlopen support... yes checking if heterogeneous support should be enabled... no checking if want trace file debugging... no checking if want full RTE support... yes checking if want fault tolerance... Disabled fault tolerance checking if want IPv6 support... yes (if underlying system supports it) checking if want orterun "--prefix" behavior to be enabled by default... no checking for package/brand string... Open MPI flakid@linux-38c6 Distribution checking for ident string... 1.4.1 checking whether to add padding to the openib control header... no checking whether to use an alternative checksum algo for messages... no ================================================== ========================== == Compiler and preprocessor tests ================================================== ========================== *** C compiler and preprocessor checking for style of include used by make... none checking for gcc... gcc checking for C compiler default output file name... configure: error: in `/home/flakid/OpenFOAM/ThirdParty-1.7.1/openmpi-1.4.1': configure: error: C compiler cannot create executables See `config.log' for more details. + make ./Allwmake: line 102: make: command not found + make install ./Allwmake: line 103: make: command not found + make distclean ./Allwmake: line 104: make: command not found ======================================== Build Scotch decomposition library + cd scotch_5.1/src + mkdir -p /home/flakid/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt + make scotch ./Allwmake: line 187: make: command not found ======================================== Build Metis decomposition + cd metis-5.0pre2 + cpMakeFiles metis + set +x cpMakeFiles metis . + wmake libso GKlib /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso libmetis /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created ======================================== Build ParMetis decomposition. Requires MPI. ======================================== Build ParMGridGen + cd ParMGridGen-1.0 + cpMakeFiles ParMGridGen + set +x cpMakeFiles ParMGridGen . + wmake libso MGridGen/IMlib /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso MGridGen/Lib /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created ======================================== Done ThirdParty Allwmake ======================================== + wmakePrintBuild -check no git description found + /bin/rm -f 'OpenFOAM/Make/linux64GccDPOpt/global.?' + wmakeLnInclude OpenFOAM + wmakeLnInclude OSspecific/POSIX + Pstream/Allwmake + wmake libso dummy /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers + WM_OPTIONS=linux64GccDPOptOPENMPI + wmake libso mpi /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOptOPENMPI/objectFiles' could not be created + wmake libo OSspecific/POSIX not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso triSurface /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso edgeMesh /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso surfMesh /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + decompositionMethods/AllwmakeLnInclude + wmakeLnInclude decompositionMethods + wmakeLnInclude metisDecomp + wmakeLnInclude parMetisDecomp + wmakeLnInclude scotchDecomp + dummyThirdParty/Allwmake + wmake libso scotchDecomp /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso metisDecomp /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso parMetisDecomp /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso finiteVolume /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso genericPatchFields /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found + wmake libso dynamicMesh /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso dynamicFvMesh /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found + wmake libso ODE /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso randomProcesses /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found + wmake libso liquidMixture + wmake libso solids /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso solidMixture /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso basic /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso reactionThermo /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso laminarFlameSpeed /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso chemistryModel + wmake libso radiation /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso barotropicCompressibilityModel /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + transportModels/Allwmake + wmake libso incompressible /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso interfaceProperties /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + turbulenceModels/Allwmake + LES/Allwmake + wmakeLnInclude ../incompressible/LES + wmake libso LESfilters /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found + incompressible/Allwmake + wmake libso turbulenceModel /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso RAS /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso LES /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + compressible/Allwmake + wmake libso turbulenceModel /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso RAS + lagrangian/Allwmake + wmake libso basic /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso solidParticle /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso intermediate /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso dieselSpray + wmake libso coalCombustion /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + molecularDynamics/Allwmake + wmake libso potential /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found + postProcessing/Allwmake + wmake libo postCalc /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso foamCalcFunctions /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + functionObjects/Allwmake + wmake libso field /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created + wmake libso forces /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 198: make: command not found /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 199: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created /home/flakid/OpenFOAM/OpenFOAM-1.7.1/wmake/wmake: line 168: make: command not found What do I need to do? |
December 25, 2010, 19:29 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Flakid and welcome to the forum!
You need to install make?! Since you are installing OpenFOAM in openSUSE 11.3, follow these instructions: Installing OpenFOAM 1.7 on openSUSE 11.3 You can't go wrong if you follow them carefully! Best regards and good luck! Bruno
December 26, 2010, 03:33 |
#3 | |
wenzhongqing
Rep Power: 15 |
do you know how to set proxy in suse11.3, I have no idea where to set the port when setting proxy. Testing the proxy, an error occured : " p, li { white-space: pre-wrap; } * Port number too large: 304133 curl: (3) Port number too large: 304133 * About to connect() to proxy 10.10.2.54 port 1080 (#0) * Trying 10.10.2.54... % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0Connection refused * couldn't connect to host * Closing connection #0 curl: (7) couldn't connect to host " So I couldn't use YaST to install cmake, flex, and so on.. |
December 26, 2010, 07:34 |
Bruno Santos
Rep Power: 128 |
Proxy in openSUSE? I've never needed to set-up proxy in Linux (nor Windows), so I don't have experience with it.
Google came up with this on the first link: How to enable proxy on opensuse 11.3 Good luck!
December 26, 2010, 09:00 |
Alberto Passalacqua
Rep Power: 36 |
There is a golden rule for SUSE users. If you are looking for a system (not application-specific) setting, in 99% of the cases, that setting can be found in YaST.
Also, as a suggestion, the default installation does not bring YaST in all its power, since it is customized for desktop use. YaST can do much more (configure servers, services, tools, ...). Search for YaST (use "yast" keyword) in the package installer, and have a lot fun . OpenSUSE has also nice manuals:
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
December 27, 2010, 01:01 |
wenzhongqing
Rep Power: 15 |
Thx very much!
I have install what is needed. After taring the packages , add the line: .$HOME/OpenFOAM/OpenFOAM-1.7.1/etc/bashrc to .bashrc in ./home/flakid/ and source $HOME/.bashrc but still bash: ./home/flakid/OpenFOAM/OpenFOAM-1.7.1/etc/bashrc: No such file or directory I cannot figure out. |
December 27, 2010, 18:34 |
#7 | |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Flakid: Quote:
. $HO Code:
source $HOME/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc I used the name "OpenFOAM-1.7.0" because it's what it is in Alberto's blog post, but in your case it's "OpenFOAM-1.7.1"... but I guess that you already know OK, finally, instead of running "source ~/.bashrc", you can simply open a new terminal/console window or tab and it will do that on it's own. Best regards and good luck! Bruno
December 28, 2010, 00:12 |
wenzhongqing
Rep Power: 15 |
Exactly!
I 'm so stupid. I have install flex,cmake,gcc c++,and so on.. Again some error: /bin/sh: g++: command not found make[2]: *** [Make/linux64GccDPOpt/chemkinToFoam.o] Error 127 make[2]: Target `/home/flakid/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/chemkinToFoam' not remade because of errors. make[2]: Leaving directory `/home/flakid/OpenFOAM/OpenFOAM-1.7.1/applications/utilities/thermophysical/chemkinToFoam' make[1]: *** [chemkinToFoam] Error 2 Do you have some advise. Thx. |
December 28, 2010, 02:04 |
#9 |
Alberto Passalacqua
Rep Power: 36 |
To install all what you need to develop C++ applications in openSUSE, you simply need a few clicks in YaST.
Open YaST -> Software -> Package manager (software manager) Assuming you use KDE, in the top-left corner there is a drop-down menu. Choose "Patterns". Scroll down the list with icons, and select "C/C++ development". Accept and complete the installation (See figure, sorry for the Italian text). This will set your openSUSE up to compile OpenFOAM.
December 28, 2010, 04:09 |
#10 |
wenzhongqing
Rep Power: 15 |
My system is openSUSE 11.3, and there is only software manament, in which, there are views, package Groups, RPM Groups, Languages, Repositories.
Under Package Groups, there is Development --Languages--C/C++, cannot choose. And I have installed patterns-openSUSE-devel_C_C++ manuelly before. THX. Still the problem. |
December 28, 2010, 06:15 |
#11 | |
Alberto Passalacqua
Rep Power: 36 |
If you have that pattern installed, g++ is installed for sure. Anyway, check if the package gcc-c++ is installed with: rpm -qa gcc* which lists all the packages related to gcc. Best,
December 28, 2010, 07:28 |
#12 | |
wenzhongqing
Rep Power: 15 |
rpm -qa gcc* get: gcc-4.5-4.2.x86_64 gcc-c++-4.5-4.2.x86_64 |
December 28, 2010, 08:10 |
#13 | |
Alberto Passalacqua
Rep Power: 36 |
You should have something like: gcc45-4.5.0_20100604-1.12.x86_64 gcc-4.5-4.2.x86_64 gcc-c++-4.5-4.2.x86_64 gcc45-c++-4.5.0_20100604-1.12.x86_64 and eventually the "info" packages.
December 28, 2010, 08:31 |
#14 |
wenzhongqing
Rep Power: 15 |
So what's the pattern name,how can I install it manully?Not in the pattern.
December 28, 2010, 08:33 |
#15 |
Alberto Passalacqua
Rep Power: 36 |
You can install the "C/C++ development" pattern as I told you above, or you can add the packages you need manually.
A pattern is simply a collection of packages. Good luck,
December 28, 2010, 08:39 |
#16 |
wenzhongqing
Rep Power: 15 |
I cannot install it as you told me above, please tell me a package name that I can found in Package Search in openSUSE website, so I can download and install.
Thanks. And why I install x86_64 patterns-openSUSE-devel_C_C++-11.3-22.1.x86_64.rpm is not OK? |
December 28, 2010, 08:48 |
#17 |
Alberto Passalacqua
Rep Power: 36 |
You have the list of packages you need in post #13. The pattern package should pull the required packages too.
P.S. I think you should really take the time to learn how to use your Linux system. It is quite important to be productive and to work on it easily. Best,
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0 | alberto | OpenFOAM | 12 | July 28, 2010 11:59 |
OpenFOAM Live USB based on openSUSE 11.1 created with SUSE Studio | alberto | OpenFOAM | 40 | May 23, 2010 16:15 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
