OF 1.7.1 on Fedora 13
Old   November 4, 2010, 20:21
Default OF 1.7.1 on Fedora 13
Tony
tonyuprm is on a distinguished road
Im trying to install OpenFOAM on a Fedora 13 machine but the installer stops after running for 2 hours with the following error:
make: Target `application' not remade because of errors.
Attached is the log file.
make.log.tar.gz
Thanks
tonyuprm is offline   Reply With Quote
Old   November 5, 2010, 10:12
Retired Super Moderator
Bruno Santos
Hi Tony,
The solution is pretty simple: run Allwmake again
There is a bug in Allwmake in the ThirdParty folder, which doesn't create the necessary folder for libscotch to be copied to. But the second time it's executed, the folder already exists from the previous run.
Best regards,
Bruno
Old   November 6, 2010, 01:21
Default Error in making the target 'application'
Achin is on a distinguished road
Hi
I had the same problem i.e
make: *** [thermophysical] Error 2
This continued to occur even on 3rd run of ./Allwmake. I am trying to install OF in Fedora 13. Kindly Help.
Achin is offline   Reply With Quote
Old   November 6, 2010, 04:58
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Let's see, in your make log you have:
/usr/bin/ld: cannot find -liberty
Can you 'locate libiberty'?
I think you need to install binutils. If you're using fedora then 'yum install binutils-devel' as root.
I just installed Fedora 14, I'll be installing OF on that when I have time.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   November 6, 2010, 10:52
Hi Laurance
I installed binutils also but still application couldn't be made.
Abhinav
Old   November 6, 2010, 15:06
Bruno Santos
Greetings Abhinav,
Could you post the new make.log file?
Just in case you don't know what I'm talking about, run Allwmake like so:
./Allwmake > make.log 2>&1
tar -czf make.log.tar.gz make.log
Then attach the file "make.log.tar.gz" to your next post.
Best regards,
Bruno
Old   November 6, 2010, 15:20
Hi Bruno
Here is the log file.
Abhinav
Old   November 6, 2010, 15:26
Bruno Santos
Hi Abhinav,
You don't even gcc nor g++ installed? Here are the packages you need to install in Fedora before you start building OpenFOAM:
Originally Posted by http://www.idurun.com/?p=544
Before compiling the packages, you must prepare some necessary packages on your system:
  • binutils-static # it provides libiberty.a and others
  • python-devel # if you want the python support in paraview
  • qt-devel # I suppose you like it. Yes, it provides qmake-qt4
  • cmake # it is mandatory for compiling paraview
  • flex
Please use yum to install them:
sudo yum install -y binutils-static python-devel qt-devel cmake flex
Edit: I reviewed the file and noticed you are installing OpenFOAM 1.7.1 (in Fedora 13, I guess). You'll need to do a little modification before starting to build it:
Originally Posted by http://www.openfoam.com/mantisbt/view.php?id=15
In $WM_DIR/rules/linux64Gcc/c++, change LINKEXE to this:
LINKEXE = $(CC) $(c++FLAGS) -Xlinker --add-needed
Edit2: Sorry, forgot to mention that you also need to install gcc and g++ I thought that blog I quoted had the whole list Here is another yum command line form an old post of mine for Fedora 12:
Originally Posted by wyldckat View Post
yum install gcc gcc-c++ binutils-devel flex git-core wget cmake qt4-devel python-devel readline-devel bison
Good luck!
Bruno
Last edited by wyldckat; November 6, 2010 at 15:38. Reason: see "Edit:" and "Edit2:"
Old   November 6, 2010, 15:36
Hi Bruno
I checked and found that I dont have g++ installed although gcc is there and working. Any ways I'll install other packages first. Should I do "yum install gcc-c++".
Abhinav
Old   November 6, 2010, 15:41
Bruno Santos
Hi Abhinav,
Yep review my previous post... I've been editing it... twice I've had to review it... this is really the end of my week, I'm just running on fumes
A final note (or so I hope ): check if you have the file /lib/gcc. If not, run this in superuser/root:
ln -s `which gcc` /lib/gcc
Best regards,
Bruno
Old   November 6, 2010, 17:08
Wow, no g++? Welcome to the wonderful world of Fedora!
Old   November 7, 2010, 13:14
VNPenguin
vnpenguin is on a distinguished road
No problem. Just "yum install gcc\*"
vnpenguin is offline   Reply With Quote
Old   November 9, 2010, 00:08
Tony
Thanks,
I tried running the Allwmake script again but it didnt work. I installed some dependencies which i was missing and changed the LINKEXE line that Bruno suggested. Now the installation is working fine.
Thanks,
Tony
Old   November 11, 2010, 10:59
Thumbs up
  #14
VNPenguin
With the patch of $WM_DIR/rules/linux64Gcc/c++ suggested by Bruno, I can build OpenFOAM 1.7.1 on Fedora 14 too
Old   November 12, 2010, 12:44
Here is a log file.
I installed the all the dependencies.
I changed the LINEXE file as
I tried installing as root since I observed "Permission Denied" for some files in log file.
But still there is the problem.
any ideas?
I am trying to install OpenFoam 1.7 on Fedora 13.
Sorry no logfile could be uploaded as it's size was more than allowed.
Abhinav
Old   November 12, 2010, 13:03
Bruno Santos
Hi Abhinav,
Compress the log like this:
tar -czf make_log.tar.gz make.log
Best regards,
Bruno
Old   November 12, 2010, 14:28
Hi Bruno
It was the compressed file I was talking about which couln't be uploaded as it was 126 kb while the allowed size is of 97kb for one attachment. Any way I made the whole log in two parts and now I have attached two compressed files. I was trying to install as root.
Regards
Abhinav
Old   November 12, 2010, 17:36
Bruno Santos
Hi Abhinav,
Mmm, this week was longer than I thought... I didn't even remember about telling you how to compress the file in a previous post
OK, the only thing that pops into my head is this: you have Fedora i686 and not x86_64, therefore the correct file to change would be "$WM_DIR/rules/linuxGcc/c++". But to be really sure of which rule version you are using, try this:
echo $WM_DIR/rules/$WM_ARCH$WM_COMPILER/c++
Because the errors you are getting are associated to that LINKEXE line, namely the missing two options for Fedora!
Best regards,
Bruno
Old   November 13, 2010, 06:26
Also, why not use the Git repository. It's up to date with all those fixes and will compile on Fedora 13/14 no problem.
Old   November 13, 2010, 09:26
Thumbs up
  #20
VNPenguin
Yes, you're right. With Git repo I just build no problem on Fedora 14
Thanks,
Error compiling 1.6.x on Fedora 12 vnpenguin OpenFOAM Installation 7 July 24, 2012 14:52
OpenCFD release OpenFOAMŪ version 1.7.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 August 26, 2010 11:40
Fedora 10 OpenFOAM15 philippose OpenFOAM Installation 7 February 18, 2009 04:37
STAR-CD 3.268in Fedora 8 Thomas Stockheim Siemens 3 April 28, 2008 03:43
FEDORA CORE and PARALLEL processing Tuks CFX 2 August 20, 2005 11:05
