Problem running wmake on simpleFoam
Old   March 1, 2011, 11:50
Default Problem running wmake on simpleFoam
Greg Givogue
Greg Givogue is on a distinguished road
Hi Everyone!
I've corrected the KOmegaSST.C bug in 1.7.1 but am unable to recompile simpleFoam using wmake.
First I run 'touch simpleFoam.C' then...
greggivogue@ubuntu:/opt/openfoam171/applications/solvers/incompressible/simpleFoam$ wclean
greggivogue@ubuntu:/opt/openfoam171/applications/solvers/incompressible/simpleFoam$ wmake
mkdir: cannot create directory `linux64GccDPOpt': Permission denied
/bin/sh: cannot create linux64GccDPOpt/options: Directory nonexistent
make: *** [linux64GccDPOpt/options] Error 2
/opt/openfoam171/wmake/MakefileFiles:39: linux64GccDPOpt/options: No such file or directory
make: *** No rule to make target `linux64GccDPOpt/options'. Stop.
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
Can someone please chime in and help me with this likely bonehead problem! I'm really stuck here. It looks like it has to do with permissions but I'm not really sure how to fix this... Thanks!
Greg Givogue is offline   Reply With Quote
Old   March 1, 2011, 12:42
Greg Givogue
Problem solved but changing permissions.
Old   April 23, 2011, 03:59
Default a similar question?
Quan Zhou
iampolaris is on a distinguished road
Hi, Greg.
I have encountered a similar problem like you, can you tell me how to change the permission and solve it?
Thx.
iampolaris is offline   Reply With Quote
Old   April 23, 2011, 10:10
Retired Super Moderator
Bruno Santos
Greetings to both!
@iampolaris: Although I'm against modifying permissions on root folders, here is what you can do:
sudo chmod -R o+w /opt/openfoam171
This will give all users, who aren't part of the root group, write permissions to OpenFOAM's folder.
This is very dangerous, since this way anyone can damage your OpenFOAM installation. It would be advisable that after you do the tweaks you want to do, you reverse the permissions by running:
sudo chmod -R o-w /opt/openfoam171
Best regards,
Bruno
Old   April 23, 2011, 20:40
Greg Givogue
This is basically what I did. Good luck
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 14:44
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 09:42
Problem with running FoamX in a distributed environment susana OpenFOAM Pre-Processing 1 March 28, 2007 17:11
