[OpenFOAM.org] problem with instaling openfoam-2.0.0 on ubuntu 18.04
Like Tree1Likes
  • 1 Post By wyldckat
Old   November 6, 2018, 11:18
Default problem with instaling openfoam-2.0.0 on ubuntu 18.04
Alireza
alireza.sh is on a distinguished road
Dear users
I am new in Open Foam and Ubuntu. I want to install the OpenFOAM-2.0.0 from source pack on Ubuntu 18.04 but i am failed in it. I do it according to below link:
https://openfoam.org/download/2-0-0-source/
I attached the Log_Allwmake file to see all of the errors.
can any one help me to solve the problem???
thanks a lot
alireza.sh is offline   Reply With Quote
Old   November 6, 2018, 19:17
Retired Super Moderator
Bruno Santos
Quick answer: Very interesting... I'm only seeing issues with compiling with Flex... try running the following commands:
#Go into OpenFOAM's main source folder
cd $WM_PROJECT_DIR
#Change how the flex version is checked
find src applications -name "*.L" -type f | xargs sed -i -e 's=\(YY\_FLEX\_SUBMINOR\_VERSION\)=YY_FLEX_MINOR_VERSION < 6 \&\& \1='
Then run Allwmake the same you've done before.
Old   November 10, 2018, 06:00
Alireza
cd $WM_PROJECT_DIR
Dear Bruno
Thanks a lot for your reply
I run the commands and i still see a lot of error. The new errors have been reported in the attached file.
I want to run the HACFOAM program and it is the reason why I should install the OpenFoam2.0.0.
can anyone help me how to solve this problem?? I have searched in the web a lot but i can not find any things.
Thanks a lot
Old   November 11, 2018, 17:19
Bruno Santos
Quick answer: I didn't notice it on the first log file (edit: the first log did have it), but this:
no ThirdParty sources found - skipping
indicates that you did not download and unpack the "ThirdParty-2.0.0.gtgz" package in the correct location. The unpacked folder is meant to be placed next to OpenFOAM-2.0.0, e.g.:
  • OpenFOAM
    • OpenFOAM-2.0.0
    • ThirdParty-2.0.0
This is necessary because Open-MPI 1.5.3 is needed for building with this version of OpenFOAM.
Old   November 12, 2018, 03:32
Unhappy
Alireza
  • OpenFOAM
    • OpenFOAM-2.0.0
    • ThirdParty-2.0.0
Dear Bruno
I am very appreciative of your notification.I did it but I did not make the source again from the first because it take a lot of time (about 4h). I make the source on the previous one (about 5 minute) but also i have a lot of error.
Old   November 12, 2018, 17:26
Bruno Santos
OK, what at first seemed like a fairly simple fix with OpenFOAM 2.0.x, is now an ever expanding list of problems with compiling 2.0.0...
I will not have time before the upcoming weekend to test this myself and work through the issues to write a wiki page on this topic. My best suggestion right now is that you install Ubuntu 14.04 inside a virtual machine and follow the instructions given here: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04
It's not a great solution, but it's the quickest one I'm able to provide right now.
If you can wait until this upcoming weekend (17-18 of November 2018), I may be able to look into this myself in more detail.
alireza.sh likes this.
Old   November 14, 2018, 02:04
Alireza
Dear Bruno
I appreciate your prompt response to my question. If it is possible for you to write a wiki page on this topic, i prefer to wait until 18 of November but I also try to install it on Ubuntu 14.04 as you suggested.
thanks a lot
Old   November 18, 2018, 02:17
Alireza
Dear Bruno
According to your previous post, I run the Openfoam-2.0.0 on ubuntu14.04. But it is necessary for me to run it on Ubuntu 18.04
I would appreciate if you help me
Thanks a lot
Old   November 22, 2018, 05:12
Default problem with instaling openfoam-2.0.0 on ubuntu 14.04
Alireza
Dear users
I tried to make the openfoam-2.0.0 on ubuntu 14.04. At first I tried to do it on ubuntu for i386 in virtual Box and it worked correctly.
I follow:https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04
After that i decided to make openfoam-2.0.0 on ubuntu 14.04 for x86_64 on a real machine. But I got the errors.
Thanks a lot
Old   November 22, 2018, 05:35
Daniel
Daniel_Khazaei will become famous soon enough
just looking at the first line:
gcc-4.4-4.4-4.4 -m64  -Wall -O3   -fPIC dirToString.c -o /home/alireza/OpenFOAM/OpenFOAM-2.0.0/wmake/platforms/linux64Gcc44/dirToString
you have some how messed up how OpenFOAM reads the gcc version, it should be:
gcc-4.4
not
gcc-4.4-4.4-4.4
probably executing one command multiple times at step 7?
check these two files here:
OpenFOAM-2.0.0/wmake/rules/linux*Gcc44/c
OpenFOAM-2.0.0/wmake/rules/linux*Gcc44/c++
Daniel_Khazaei is offline   Reply With Quote
Old   November 22, 2018, 10:46
Fatih Ertinaz
fertinaz is on a distinguished road
See the first two lines of your log file:
make: gcc-4.4-4.4-4.4: Command not found
There is an obvious typo in the compiler definition. Correct that by removing last 4 4s and retry.
fertinaz is offline   Reply With Quote
Old   November 22, 2018, 11:09
Alireza
gcc-4.4
not
gcc-4.4-4.4-4.4
Dear Daniel
It is working.
Tanks a lot
[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 JGadelho OpenFOAM Community Contributions 35 November 6, 2023 11:42
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
Wigley Hull with OpenFoam 2.0.0 problem Stephy OpenFOAM Bugs 19 October 12, 2020 10:22
[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS mukut OpenFOAM Installation 9 January 19, 2015 00:48
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
