Installing OpenFOAM with SYSTEM MPI while using Third-Party libs
Like Tree2Likes
  • 2 Post By wyldckat
Old   June 21, 2011, 03:31
Default Installing OpenFOAM with SYSTEM MPI while using Third-Party libs
Massimiliano Culpo
m.culpo is on a distinguished road
I am trying to install OpenFOAM 1.7.1 on a linux cluster using the OpenMPI libraries installed on the system. Anyhow, I am not able to compile cleanly the Third party libraries (metis,scotch). In fact, while a complete installation with Gcc 4.5.2 and Third-party OpenMPI:
${WM_MPLIB:=OPENMPI}; export WM_MPLIB
produces in the subdirectory:
~/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/openmpi-1.4.1
the following shared objects:
libmetis-parmetis.so libparMetisDecomp.so libparmetis.so libPstream.so libptscotcherrexit.so libptscotch.so
the same installation with:
${WM_MPLIB:=SYSTEMOPENMPI}; export WM_MPLIB
produces in the directory:
~/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/openmpi-system
only "libPstream.so", i.e. it seems that Third-party libraries are not built. Even though a bad-hack to make things work is to manually copy the missing shared objects from the first directory to the second, I would like to ask if anybody knows a clean way to compile and install OpenFOAM using SYSTEM OpenMPI. I apologize if the question is somehow trivial, but I am an OpenFOAM beginner and I was not able to find further clues on the subject on the web.
Many thanks in advance to anyone answering
m.culpo is offline   Reply With Quote
Old   June 25, 2011, 07:57
Retired Super Moderator
Bruno Santos
Greetings Massimiliano and welcome to the forum!
I think you should check this bug report: http://www.openfoam.com/mantisbt/view.php?id=79
To apply the patch, run:
foam3rdParty
gunzip ThirdParty_Allwmake.diff.gz
patch -p0 < ThirdParty_Allwmake.diff
Running Allwmake a second time before applying this patch might also fix the problem!
Best regards,
Bruno
Old   July 1, 2011, 08:07
Massimiliano Culpo
Hi Bruno,
and many thanks for the hint!
Anyhow, I tried the patch and it does not seem to solve the problem. :-(
Old   July 1, 2011, 20:03
Bruno Santos
Hi Massimiliano,
OK, I had to test this for myself... And came to the same problem! Then I remembered of another bug report I made a while back: http://www.openfoam.com/mantisbt/view.php?id=96
Basically, edit the file etc/settings.sh, search for the following block of code in the SYSTEMOPENMPI entry and add the line in bold:
    export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/$mpi_version
    export MPI_ARCH_PATH="${libDir%/*}"
    unset mpi_version libDir
Start a new terminal or source etc/bashrc once again and run Allwmake. This should do the trick
Best regards,
Bruno
yanxiang and alsaeng like this.
Old   July 2, 2011, 03:51
Massimiliano Culpo
The last solution works perfectly!
Many thanks,
Massimiliano
Old   July 3, 2011, 03:48
Alberto Passalacqua
Many thanks,
Massimiliano
Changing settings.sh is going to potentially cause problems with git, if you use OpenFOAM 2.0.x, since if the file is changed in the repository, git won't fast-forward and it will ask you to merge.
Custom settings like this should go into the file "prefs.sh".
You find an example of this file in ~/OpenFOAM/OpenFOAM-2.0.x/etc/config/example/, and the file should be saved into ~/OpenFOAM/OpenFOAM-2.0.x/etc.
Simply uncomment "export WM_MPLIB=SYSTEMOPENMPI" in the example, and you are done.
Best,
Alberto Passalacqua
problems with installing OpenFOAM 1.6 su_junwei OpenFOAM Installation 8 September 10, 2009 12:54
Installing Open Foam and needed packages on shared disk for cluster environment k3di OpenFOAM Installation 1 July 8, 2009 07:06
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
MPI profiling OpenFOAM damBreak3D application mellanoxuser OpenFOAM Running, Solving & CFD 0 April 13, 2008 23:04
