July 8, 2011, 11:24 |
OpenFOAM 2.0.x libscotch issues
Hello
I am trying to compile 2.0.x and I believe I am having issues with decomposition libraries. Solvers and such compile fine, but snappyHexMesh for example does not. I am attaching a log of Allmake which seems to successfully make the necessary ThirdParty libs. The first error I locate in the log: Code:
+ wmake libso scotchDecomp g++: no input files make: *** [/l/gfilip/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/dummy/libscotchDecomp.so] Error 1 Code:
/usr/bin/ld: cannot find -lptscotchDecomp collect2: ld returned 1 exit status make[3]: *** [/l/gfilip/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/bin/snappyHexMesh] Error 1 Any ideas? |
July 9, 2011, 05:27 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Grzegorz,
I don't understand. Everything was fine in the previous build you posted in the other thread (this post http://www.cfd-online.com/Forums/ope...tml#post315198 #32)! What did you do or change to cause this error? Best regards, Bruno
July 10, 2011, 00:46 |
Hello Bruno,
In the previous post, I had both warnings and ld errors. After a git pull, the warnings went away but these errors posted above remained. Just to be clear, when I posted last, most applications did not work outside of checkMesh and some other utilities. Snappy definitely did not work at that time either. The git pull resolved the solver and most application issues, but sHM is still not compiling. Thanks Greg |
July 10, 2011, 07:04 |
Bruno Santos
Rep Power: 128 |
Hi Greg,
OK, now I'm getting a better notion of what happened. With the git version sometimes we have to start the build process from scratch once again. When too many changes occur, the wmake build system is unable to cope with the changes and gets confused. So, to re-start the building process, here's what you do: Code:
foam wcleanAll wcleanLnIncludeAll Code:
./Allwmake > make.log 2>&1 Best regards and good luck! Bruno
July 11, 2011, 11:23 |
Bruno,
Thank you very much, that did the trick! |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
[OpenFOAM] ParaView-3.7.0(cvs) + OpenFOAM Reader issues | philippose | ParaView | 15 | February 15, 2010 04:49 |
Issues with OpenFoam | sanjibdsharma | OpenFOAM | 0 | August 14, 2009 08:41 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
OpenFOAM 15 and CentOS 52 installation issues | remrich | OpenFOAM Bugs | 9 | March 20, 2009 01:48 |
