September 29, 2011, 02:56 |
OpenFoam 2.0.1 installation
Shailesh Kumar Gupta
Rep Power: 16 |
Dear Foamers,
I tried to install the newest OpenFOAM version 2.0.1. on Ubuntu 10.04 LTS. When running foamInstallationTest I get the following output: Quote: Executing ./foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: tcsh Host: shailesh-desktop OS: Linux version 2.6.32-33-generic ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/shailesh/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/shailesh/OpenFOAM/shailesh-2.0.1 no no $WM_THIRD_PARTY_DIR /home/shailesh/OpenFOAM/ThirdParty-2.0.1 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/shailesh/OpenFOAM/OpenFOAM-2.0.1 yes yes yes $FOAM_APPBIN ...AM-2.0.1/platforms/linuxGccDPOpt/bin yes yes yes $FOAM_SITE_APPBIN ...te/2.0.1/platforms/linuxGccDPOpt/bin no no $FOAM_USER_APPBIN ...sh-2.0.1/platforms/linuxGccDPOpt/bin no no $WM_DIR ...ailesh/OpenFOAM/OpenFOAM-2.0.1/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...AM-2.0.1/platforms/linuxGccDPOpt/lib yes yes yes $FOAM_SITE_LIBBIN ...te/2.0.1/platforms/linuxGccDPOpt/lib no no $FOAM_USER_LIBBIN ...sh-2.0.1/platforms/linuxGccDPOpt/lib no no $MPI_ARCH_PATH ...0.1/platforms/linuxGcc/openmpi-1.5.3 yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.35 /usr/bin/flex gcc 4.4.3 /usr/bin/gcc gzip 1.3.12 /bin/gzip tar 1.22 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/shailesh/OpenFOAM/OpenFOAM-2.0.1/platforms/linuxGccDPOpt/bin/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). I am getting compiling error as + wmake libso OpenFOAM SOURCE=global/global.Cver ; sed -e 's!VERSION_STRING!2.0.1!' -e 's!BUILD_STRING!2.0.1!' $SOURCE > Make/linuxGccDPOpt/global.C; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IMake/linuxGccDPOpt -IlnInclude -I. -I/home/shailesh/OpenFOAM/OpenFOAM-2.0.1/src/OpenFOAM/lnInclude -I/home/shailesh/OpenFOAM/OpenFOAM-2.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/global.C -o Make/linuxGccDPOpt/global.o fixedValuePointPatchFields.o: file not recognized: File truncated collect2: ld returned 1 exit status make: *** [/home/shailesh/OpenFOAM/OpenFOAM-2.0.1/platforms/linuxGccDPOpt/lib/libOpenFOAM.so] Error 1 Please help me to resolve this error and make.log file has been attached. Thank you Shailesh Last edited by shailesh.nitk; September 29, 2011 at 04:37. |
October 1, 2011, 15:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Shailesh,
Interesting, according to the error it almost seems like that you were running out of disk space... OK, try this before running Allwmake once again: Code:
foam wclean libso src/OpenFOAM Code:
md5sum OpenFOAM-2.0.1.gtgz If it's OK, try unpacking it once again, without removing the current installation - this should fix any damaged files. Then run Allwmake once again! Best regards and good luck! Bruno
October 3, 2011, 09:00 |
Rep Power: 16 |
Thanks you Bruno for your reply.
I was able to solve this issue. The installation issue was due to binutils-dev not installed on my Ubuntu 10.04 LTS. I am able to compile the OpenFOAM. I have run few tutorial. I want to modify or enhancement some utility to get the meshing information. I would like to know How to include new c++ files or new development into openFOAM. Could you please help me on this? Best regards, Shailesh |
October 3, 2011, 10:55 |
Bruno Santos
Rep Power: 128 |
Hi Shailesh,
Here you go: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam - read and do the steps in this tutorial to learn a bit more about how things work! Best regards and good luck! Bruno
October 4, 2011, 08:50 |
Rep Power: 16 |
Thank you again Bruno for this tutorial. This tutorial is really very good. Now I am able to include my own files into OpenFOAM.
OpenFoam 2.0.0 installation | Jan_Peters | OpenFOAM Installation | 86 | April 27, 2012 05:32 |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 14:06 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
