August 26, 2013, 13:10 |
upgrade 2.2.0 to 2.2.1
Ehsan
Rep Power: 26 |
for installing 2.2.1 version we should install it from first?isn't it possible to upgrade from 2.2.0?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
August 26, 2013, 18:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
You can have both OpenFOAM 2.2.0 and 2.2.1 installed at the same time.
But you'll only be able to use one version per terminal window/tab, as explained here: Advanced tips for working with the OpenFOAM shell environment
August 26, 2013, 18:16 |
Ehsan
Rep Power: 26 |
hi Bruno
I said it not clear,sorry. I mean should i download 2.2.1 necessarily ant isn't there a way to upgrade 2.2.0 to 2.2.1 without downloading unchanged parts(files)?
August 27, 2013, 16:54 |
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
Mmm... well, for the Debian package, there isn't such a possibility. I know that openSUSE and RPM based Linux Distributions support partial RPM updates, which only provide a patch for the actual update. But the official OpenFOAM distribution does not have this feature for the RPM packages that are released for Fedora and openSUSE. As for Debian packages, I'm not aware of any patch based mechanism being used. The only way I can think of is to follow the git versions of OpenFOAM, where the source code updates are relative. Problem is that you need to rebuild the libraries/applications for which the source code was modified. And there is the risk of having an unstable installation of OpenFOAM, such as what happened back in... I can't remember if it was 2.0.x or 2.1.x, but I remember that in one of them, parts of the combustion/diesel models stopped working... The bottom line is: the software is free and open source, but you better have a good internet access Or download files at the University... But in the end: you are almost finishing your master thesis. Keep in mind that any upgrade can be a risk at this stage. Best regards, Bruno
Density_based turbo with OpenFoam 2.2.0 | eddykendo | OpenFOAM | 4 | March 2, 2014 06:05 |
ESI-OpenCFD releases OpenFOAMŪ 2.2.1 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 2 | August 7, 2013 00:26 |
OpenFOAM 2.2.0 and 2.1.0 side by side errors | Neraste | OpenFOAM Installation | 2 | June 12, 2013 04:55 |
