parallel running - error while loading shared libraries: |
December 8, 2011, 10:02 |
Jiri Simonek
Rep Power: 14 |
I've have successfully installed OF20x from source pack. Everything works as a single process, e.g. if I run any application or solver it works. But the problem is in parallel. When I'm trying to run: Code:
mpirun -np 2 simpleFoam -parallel Code:
simpleFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory -------------------------------------------------------------------------- mpirun noticed that the job aborted, but has no info as to the process that caused that situation. -------------------------------------------------------------------------- Does anybody have any idea where could be a problem. Thanks. |
December 9, 2011, 04:39 |
problem SOLVED
Jiri Simonek
Rep Power: 14 |
I was checking file permission, but I haven't found anything wrong ...
anyway I recompiled OF once again in different directory and now it works fine. So I could be caused by wrong file permissions ... Strange things happen ;-) |
User fortran error when running CFX-10 in parallel | CFDworker | CFX | 3 | September 22, 2015 08:59 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
parallel running openFoam-1.5-dev | lulo | OpenFOAM | 3 | October 3, 2011 11:42 |
Running in parallel error | Madeleine P. Vincent | OpenFOAM Running, Solving & CFD | 0 | May 7, 2011 08:44 |
Running dieselFoam in parallel. | Palminchi | OpenFOAM | 0 | February 17, 2010 04:00 |
