January 13, 2012, 17:08 |
OpenFOAM on Ubuntu paraView abort build
Nansen
Rep Power: 14 |
Hi Dears,
I need some help in the installation. I am using virtual machine on my laptop vitalizing ubuntu 10.04L. I already followed the step of source pack on OpenFOAM page till Third party ./makeParaview there I got stuck with: " did not find ParaView- in these directories: WM_THIRD_PARTY_DIR=/home/nansen/OpenFOAM/ThirdParty-2.1.0 abort build " I hope this is not because of vmware. everything else works quite well on that... Thanks |
January 15, 2012, 08:57 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings sniperz and welcome to the forum!
It looks like you didn't unpack ThirdParty-2.1.0 in the right place. Run this command: Code:
ls -l /home/nansen/OpenFOAM/ThirdParty-2.1.0 Best regards, Bruno
January 15, 2012, 10:36 |
Nansen
Rep Power: 14 |
Hi Bruno,
Thank you! and thanks for the reply I tried with this but it seems the directory is there since it listed items followed: nansen@nansen-desktop:~$ ls -l /home/nansen/OpenFOAM/ThirdParty-2.1.0 total 96 -rwxr-x--- 1 nansen nansen 2170 2011-12-19 11:45 Allclean -rwxr-x--- 1 nansen nansen 9218 2011-12-19 11:45 Allwmake -rwxr-x--- 1 nansen nansen 2484 2011-12-19 11:45 AllwmakeLibccmio drwxr-xr-x 4 nansen nansen 4096 2012-01-13 22:47 etc -rwxr-x--- 1 nansen nansen 7698 2011-12-19 11:45 makeCGAL -rwxr-x--- 1 nansen nansen 3313 2011-12-19 11:45 makeCmake -rwxr-x--- 1 nansen nansen 6775 2011-12-19 11:45 makeGcc -rwxr-x--- 1 nansen nansen 3643 2011-12-19 11:45 makeLLVM -rwxr-x--- 1 nansen nansen 9185 2011-12-19 11:45 makeParaView -rwxr-x--- 1 nansen nansen 3864 2011-12-19 11:45 makeQt drwxr-xr-x 9 nansen nansen 4096 2012-01-13 22:52 openmpi-1.5.3 drwxr-xr-x 15 nansen nansen 4096 2012-01-13 22:47 ParaView-3.12.0 drwxr-xr-x 4 nansen nansen 4096 2012-01-13 22:52 platforms -rw-r----- 1 nansen nansen 8842 2011-12-19 13:50 README.html -rw-r----- 1 nansen nansen 2476 2011-12-19 13:50 README.org drwxr-xr-x 11 nansen nansen 4096 2012-01-13 22:52 scotch_5.1.11 I still don't quite understand why that problem occured. Hope there will be some traces in the infomation above I gave. thanks! |
January 15, 2012, 11:48 |
Bruno Santos
Rep Power: 128 |
I use VMPlayer very often and it's probably not a VMWare issue.
Some very small detail might have slipped by you when you were following the steps. Try running the following command and then try to build ParaView once again: Code:
wmSET
Best regards, Bruno
January 15, 2012, 13:28 |
Nansen
Rep Power: 14 |
Thank you Bruno,
I have tried several times under your guidance. however it is still not building. I will show some detail which seems a bit suspected: 1.wmSET nothing showed up after wmSET code. then I tried again ./makeParaView, problem still exists. 2. ---------- nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ echo $WM_THIRD_PARTY_DIR /home/nansen/OpenFOAM/ThirdParty-2.1.0 nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ ls -l $WM_THIRD_PARTY_DIR total 96 -rwxr-x--- 1 nansen nansen 2170 2011-12-19 11:45 Allclean -rwxr-x--- 1 nansen nansen 9218 2011-12-19 11:45 Allwmake -rwxr-x--- 1 nansen nansen 2484 2011-12-19 11:45 AllwmakeLibccmio drwxr-xr-x 4 nansen nansen 4096 2012-01-13 22:47 etc -rwxr-x--- 1 nansen nansen 7698 2011-12-19 11:45 makeCGAL -rwxr-x--- 1 nansen nansen 3313 2011-12-19 11:45 makeCmake -rwxr-x--- 1 nansen nansen 6775 2011-12-19 11:45 makeGcc -rwxr-x--- 1 nansen nansen 3643 2011-12-19 11:45 makeLLVM -rwxr-x--- 1 nansen nansen 9185 2011-12-19 11:45 makeParaView -rwxr-x--- 1 nansen nansen 3864 2011-12-19 11:45 makeQt drwxr-xr-x 9 nansen nansen 4096 2012-01-13 22:52 openmpi-1.5.3 drwxr-xr-x 15 nansen nansen 4096 2012-01-13 22:47 ParaView-3.12.0 drwxr-xr-x 4 nansen nansen 4096 2012-01-13 22:52 platforms -rw-r----- 1 nansen nansen 8842 2011-12-19 13:50 README.html -rw-r----- 1 nansen nansen 2476 2011-12-19 13:50 README.org drwxr-xr-x 11 nansen nansen 4096 2012-01-13 22:52 scotch_5.1.11 nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ echo $WM_PROJECT_DIR /home/nansen/OpenFOAM/OpenFOAM-2.1.0 nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ ls -l $WM_PROJECT_DIR total 84 -rwxr-x--- 1 nansen nansen 923 2011-11-24 17:59 Allwmake drwxr-xr-x 5 nansen nansen 4096 2011-12-29 17:41 applications drwxr-xr-x 3 nansen nansen 4096 2012-01-12 21:35 bin -rw-r----- 1 nansen nansen 35647 2011-11-24 17:59 COPYING drwxr-xr-x 6 nansen nansen 4096 2011-12-29 17:41 doc drwxr-xr-x 5 nansen nansen 4096 2012-01-13 22:55 etc drwxr-xr-x 3 nansen nansen 4096 2011-12-30 05:15 platforms -rw-r----- 1 nansen nansen 6478 2011-12-15 12:21 README.html -rw-r----- 1 nansen nansen 1590 2011-12-15 12:21 README.org drwxr-xr-x 32 nansen nansen 4096 2011-12-29 17:41 src drwxr-xr-x 16 nansen nansen 4096 2011-12-29 17:41 tutorials drwxr-xr-x 6 nansen nansen 4096 2011-12-30 05:15 wmake nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ which icoFoam /home/nansen/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/icoFoam -------- above looks A-OK right? and then here comes the thing: 3. ------- nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ echo $ParaView_DIR nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ ls -l $ParaView_DIR total 96 -rwxr-x--- 1 nansen nansen 2170 2011-12-19 11:45 Allclean -rwxr-x--- 1 nansen nansen 9218 2011-12-19 11:45 Allwmake -rwxr-x--- 1 nansen nansen 2484 2011-12-19 11:45 AllwmakeLibccmio drwxr-xr-x 4 nansen nansen 4096 2012-01-13 22:47 etc -rwxr-x--- 1 nansen nansen 7698 2011-12-19 11:45 makeCGAL -rwxr-x--- 1 nansen nansen 3313 2011-12-19 11:45 makeCmake -rwxr-x--- 1 nansen nansen 6775 2011-12-19 11:45 makeGcc -rwxr-x--- 1 nansen nansen 3643 2011-12-19 11:45 makeLLVM -rwxr-x--- 1 nansen nansen 9185 2011-12-19 11:45 makeParaView -rwxr-x--- 1 nansen nansen 3864 2011-12-19 11:45 makeQt drwxr-xr-x 9 nansen nansen 4096 2012-01-13 22:52 openmpi-1.5.3 drwxr-xr-x 15 nansen nansen 4096 2012-01-13 22:47 ParaView-3.12.0 drwxr-xr-x 4 nansen nansen 4096 2012-01-13 22:52 platforms -rw-r----- 1 nansen nansen 8842 2011-12-19 13:50 README.html -rw-r----- 1 nansen nansen 2476 2011-12-19 13:50 README.org drwxr-xr-x 11 nansen nansen 4096 2012-01-13 22:52 scotch_5.1.11 --------- after inputting echo $ParaView_DIR, it came with a line with vacancy.nothing else.perhaps you can see from it.then I continued with the last code: ------- nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ export | grep -i -e "paraview" declare -x paraview nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ ./makeParaView did not find ParaView- in these directories: WM_THIRD_PARTY_DIR=/home/nansen/OpenFOAM/ThirdParty-2.1.0 abort build --------- I get really confused... this problem is found when I source the further problem when I tried to run paraFoam and it said ParaView reader module libraries do not exist. I rechecked everything and removed Thirdparty folder and tried to re-run Allwmake and reinstall Thirdparty. Maybe I shall delete all of them and reinstall the whole OpenFOAM? Thank you again for your help! |
January 15, 2012, 13:53 |
Bruno Santos
Rep Power: 128 |
I forgot - the real test is this:
echo $ParaView_VERSION Code:
3.12.0
Another thing: you should have the ThirdParty folder ready to be used before compiling OpenFOAM. According to your latest description, it looks like you unpacked the ThirdParty package after OpenFOAM was built. If all else fails, then yes... I suppose it's better to start from scratch. A tip: to speed up the build process, define "WM_NCOMPPROCS" (notice the 2 P letters) before running "Allwmake": Code:
export WM_NCOMPPROCS=4 ./Allwmake edit: When in doubt, start a new terminal window or tab, so you can have a clean shell environment. Good luck! Bruno
January 15, 2012, 15:17 |
Nansen
Rep Power: 14 |
Hi Bruno,
Like you said, it is true that my bashrc file is damaged. I replace the whole content with the content online and it works! makeParaview worked: nansen@nansen-desktop:~$ echo $ParaView_VERSION 3.12.0 but then I made the trouble shown at very beginning again... nansen@nansen-desktop:~/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib$ paraFoam /home/nansen/OpenFOAM/OpenFOAM-2.1.0/bin/paraFoam: 36: source: not found FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake no matter how many times I do the Allwclean and Allwmake it just cannot run. Then I went to the directory cd /home/nansen/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/ I found neither Paraview file nor libPV3FoamReader_SM.so total 93704 drwxr-xr-x 4 nansen nansen 4096 2012-01-15 20:18 ./ drwxr-xr-x 4 nansen nansen 4096 2011-12-30 06:53 ../ drwxr-xr-x 2 nansen nansen 4096 2011-12-30 05:28 dummy/ -rwxr-xr-x 1 nansen nansen 1835359 2011-12-30 06:50 libautoMesh.so* -rwxr-xr-x 1 nansen nansen 226532 2011-12-30 06:15 libbarotropicCompressibilityModel.so* -rwxr-xr-x 1 nansen nansen 793203 2011-12-30 06:16 libbasicSolidThermo.so* -rwxr-xr-x 1 nansen nansen 1090833 2011-12-30 06:12 libbasicThermophysicalModels.so* -rwxr-xr-x 1 nansen nansen 262841 2011-12-30 06:50 libblockMesh.so* -rwxr-xr-x 1 nansen nansen 798311 2011-12-30 06:15 libchemistryModel.so* -rwxr-xr-x 1 nansen nansen 94624 2011-12-30 06:43 libcoalCombustion.so* -rwxr-xr-x 1 nansen nansen 860622 2011-12-30 06:37 libcombustionModels.so* -rwxr-xr-x 1 nansen nansen 326052 2011-12-30 07:34 libcompressibleEulerianInterfacialModels.so* -rwxr-xr-x 1 nansen nansen 1097755 2011-12-30 07:36 libcompressibleKineticTheoryModel.so* -rwxr-xr-x 1 nansen nansen 1682912 2011-12-30 06:36 libcompressibleLESModels.so* -rwxr-xr-x 1 nansen nansen 353119 2011-12-30 07:41 libcompressibleMultiphaseEulerianInterfacialModels .so* -rwxr-xr-x 1 nansen nansen 1097755 2011-12-30 07:42 libcompressibleMultiphaseKineticTheoryModel.so* -rwxr-xr-x 1 nansen nansen 346159 2011-12-30 07:40 libcompressibleMultiPhaseModel.so* -rwxr-xr-x 1 nansen nansen 333091 2011-12-30 07:34 libcompressiblePhaseModel.so* -rwxr-xr-x 1 nansen nansen 2581129 2011-12-30 06:34 libcompressibleRASModels.so* -rwxr-xr-x 1 nansen nansen 910111 2011-12-30 06:30 libcompressibleTurbulenceModel.so* -rwxr-xr-x 1 nansen nansen 525654 2011-12-30 06:02 libconversion.so* -rwxr-xr-x 1 nansen nansen 34623 2011-12-30 06:01 libdecompose.so* -rwxr-xr-x 1 nansen nansen 315487 2011-12-30 06:01 libdecompositionMethods.so* -rwxr-xr-x 1 nansen nansen 397862 2011-12-30 06:01 libdistributed.so* -rwxr-xr-x 1 nansen nansen 147441 2011-12-30 06:00 libdistributionModels.so* -rwxr-xr-x 1 nansen nansen 160316 2011-12-30 06:43 libdsmc.so* -rwxr-xr-x 1 nansen nansen 583705 2011-12-30 06:10 libdynamicFvMesh.so* -rwxr-xr-x 1 nansen nansen 3754656 2011-12-30 06:09 libdynamicMesh.so* -rwxr-xr-x 1 nansen nansen 327276 2011-12-30 05:26 libedgeMesh.so* -rwxr-xr-x 1 nansen nansen 357325 2011-12-30 06:53 libengine.so* -rwxr-xr-x 1 nansen nansen 308536 2011-12-30 07:45 libEulerianInterfacialModels.so* -rwxr-xr-x 1 nansen nansen 87803 2011-12-30 06:56 libextrudeModel.so* -rwxr-xr-x 1 nansen nansen 2234356 2011-12-30 06:48 libfieldFunctionObjects.so* -rwxr-xr-x 1 nansen nansen 39475 2011-12-30 05:22 libfileFormats.so* -rwxr-xr-x 1 nansen nansen 19174869 2011-12-30 06:00 libfiniteVolume.so* -rwxr-xr-x 1 nansen nansen 1130093 2011-12-30 06:45 libfoamCalcFunctions.so* -rwxr-xr-x 1 nansen nansen 843813 2011-12-30 06:48 libforces.so* -rwxr-xr-x 1 nansen nansen 2128202 2011-12-30 06:53 libfvMotionSolvers.so* -rwxr-xr-x 1 nansen nansen 804814 2011-12-30 06:01 libgenericPatchFields.so* -rwxr-xr-x 1 nansen nansen 2218693 2011-12-30 06:29 libincompressibleLESModels.so* -rwxr-xr-x 1 nansen nansen 3387042 2011-12-30 06:26 libincompressibleRASModels.so* -rwxr-xr-x 1 nansen nansen 563920 2011-12-30 06:18 libincompressibleTransportModels.so* -rwxr-xr-x 1 nansen nansen 431893 2011-12-30 06:20 libincompressibleTurbulenceModel.so* -rwxr-xr-x 1 nansen nansen 439027 2011-12-30 06:18 libinterfaceProperties.so* -rwxr-xr-x 1 nansen nansen 130484 2011-12-30 06:48 libIOFunctionObjects.so* -rwxr-xr-x 1 nansen nansen 97179 2011-12-30 06:49 libjobControl.so* -rwxr-xr-x 1 nansen nansen 1082471 2011-12-30 07:47 libkineticTheoryModel.so* -rwxr-xr-x 1 nansen nansen 4270421 2011-12-30 06:43 liblagrangianIntermediate.so* -rwxr-xr-x 1 nansen nansen 151784 2011-12-30 06:00 liblagrangian.so* -rwxr-xr-x 1 nansen nansen 1461508 2011-12-30 06:43 liblagrangianSpray.so* -rwxr-xr-x 1 nansen nansen 211694 2011-12-30 06:14 liblaminarFlameSpeedModels.so* -rwxr-xr-x 1 nansen nansen 267203 2011-12-30 06:19 libLESdeltas.so* -rwxr-xr-x 1 nansen nansen 882034 2011-12-30 06:19 libLESfilters.so* -rwxr-xr-x 1 nansen nansen 56756 2011-12-30 06:11 libliquidMixtureProperties.so* -rwxr-xr-x 1 nansen nansen 1106799 2011-12-30 06:11 libliquidProperties.so* -rwxr-xr-x 1 nansen nansen 3249266 2011-12-30 05:26 libmeshTools.so* -rwxr-xr-x 1 nansen nansen 38537 2011-12-30 06:44 libmolecularMeasurements.so* -rwxr-xr-x 1 nansen nansen 486413 2011-12-30 06:44 libmolecule.so* -rwxr-xr-x 1 nansen nansen 666502 2011-12-30 07:43 libmultiphaseInterFoam.so* -rwxr-xr-x 1 nansen nansen 722010 2011-12-30 07:41 libmultiphaseSystem.so* -rwxr-xr-x 1 nansen nansen 81768 2011-12-30 06:10 libODE.so* -rwxr-xr-x 1 nansen nansen 6451567 2012-01-15 20:18 libOpenFOAM.so* -rw-r--r-- 1 nansen nansen 270060 2011-12-30 05:15 libOSspecific.o -rwxr-xr-x 1 nansen nansen 114194 2011-12-30 06:50 libpairPatchAgglomeration.so* -rwxr-xr-x 1 nansen nansen 218665 2011-12-30 07:45 libphaseModel.so* -rwxr-xr-x 1 nansen nansen 347851 2011-12-30 06:44 libpotential.so* -rwxr-xr-x 1 nansen nansen 442336 2011-12-30 06:37 libpyrolysisModels.so* -rwxr-xr-x 1 nansen nansen 1090014 2011-12-30 06:17 libradiationModels.so* -rwxr-xr-x 1 nansen nansen 105289 2011-12-30 06:10 librandomProcesses.so* -rwxr-xr-x 1 nansen nansen 3368941 2011-12-30 06:14 libreactionThermophysicalModels.so* -rwxr-xr-x 1 nansen nansen 134874 2011-12-30 06:01 libreconstruct.so* -rwxr-xr-x 1 nansen nansen 264893 2011-12-30 06:40 libregionCoupling.so* -rwxr-xr-x 1 nansen nansen 369273 2011-12-30 06:37 libregionModels.so* -rwxr-xr-x 1 nansen nansen 716597 2011-12-30 07:19 librhoCentralFoam.so* -rwxr-xr-x 1 nansen nansen 3458645 2011-12-30 06:06 libsampling.so* -rwxr-xr-x 1 nansen nansen 81788 2011-12-30 06:01 libscotchDecomp.so* -rwxr-xr-x 1 nansen nansen 38740 2011-12-30 06:15 libSLGThermo.so* -rwxr-xr-x 1 nansen nansen 343967 2011-12-30 06:16 libsolidChemistryModel.so* -rwxr-xr-x 1 nansen nansen 43074 2011-12-30 06:11 libsolidMixtureProperties.so* -rwxr-xr-x 1 nansen nansen 386803 2011-12-30 06:40 libsolidParticle.so* -rwxr-xr-x 1 nansen nansen 84602 2011-12-30 06:11 libsolidProperties.so* -rwxr-xr-x 1 nansen nansen 68111 2011-12-30 06:11 libsolid.so* -rwxr-xr-x 1 nansen nansen 1051164 2011-12-30 06:11 libspecie.so* -rwxr-xr-x 1 nansen nansen 1707941 2011-12-30 06:39 libsurfaceFilmModels.so* -rwxr-xr-x 1 nansen nansen 1137536 2011-12-30 05:28 libsurfMesh.so* -rwxr-xr-x 1 nansen nansen 80870 2011-12-30 06:49 libsystemCall.so* -rwxr-xr-x 1 nansen nansen 119856 2011-12-30 07:12 libtabulatedWallFunctions.so* -rwxr-xr-x 1 nansen nansen 81420 2011-12-30 06:15 libthermalPorousZone.so* -rwxr-xr-x 1 nansen nansen 410994 2011-12-30 06:40 libthermoBaffleModels.so* -rwxr-xr-x 1 nansen nansen 175313 2011-12-30 06:11 libthermophysicalFunctions.so* -rwxr-xr-x 1 nansen nansen 690654 2011-12-30 06:10 libtopoChangerFvMesh.so* -rwxr-xr-x 1 nansen nansen 524811 2011-12-30 05:23 libtriSurface.so* -rwxr-xr-x 1 nansen nansen 205570 2011-12-30 06:36 libturbulenceDerivedFvPatchFields.so* -rwxr-xr-x 1 nansen nansen 236378 2011-12-30 06:18 libtwoPhaseInterfaceProperties.so* -rwxr-xr-x 1 nansen nansen 407554 2011-12-30 07:06 libuserd-foam.so* -rwxr-xr-x 1 nansen nansen 441563 2011-12-30 06:48 libutilityFunctionObjects.so* drwxr-xr-x 2 nansen nansen 4096 2012-01-13 22:52 openmpi-1.5.3/ -rw-r--r-- 1 nansen nansen 26746 2011-12-30 06:44 postCalc.o and I read some of other threads a bit related. also I found some warning when I am using Synapic Package Manager: openfoam210: Depends: libptscotch-5.1 but it is not installable Depends: libstdc++6 (>=4.5) but 4.4.3-4ubuntu5 is to be installed Recommends: libptscotch-dev but it is not installable sorry for listing so much information which may still be junk . and thank you for your time! |
January 15, 2012, 15:26 |
Bruno Santos
Rep Power: 128 |
Hold on, did ParaView get built properly?
which paraview ls -l $ParaView_DIR
January 15, 2012, 16:08 |
#9 |
Nansen
Rep Power: 14 |
Hi Bruno,
here they are nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ which paraview nansen@nansen-desktop:~/OpenFOAM/ThirdParty-2.1.0$ ls -l $ParaView_DIR ls: cannot access /home/nansen/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/paraview-3.12.0: No such file or directory I then run makeparaview again and made some log. I cannot tell if the result is ok. but it said Done. Please have a look. thanks! |
January 15, 2012, 16:14 |
#10 | |
Bruno Santos
Rep Power: 128 |
Mmm... you're using Ubuntu 10.04... check this thread: http://www.cfd-online.com/Forums/ope...tml#post337103 post #9
Oh, and the following message in bold near the end of the log indicates that things didn't work: Quote:
January 15, 2012, 17:27 |
#11 |
Nansen
Rep Power: 14 |
Hi Bruno,
Finally it works!!!I did as you instructed in that link. I was once very desperate with this Installation. Thank you very much for helping. |
January 15, 2012, 18:57 |
#12 |
Bruno Santos
Rep Power: 128 |
Hi sniperz,
You're welcome! I'm glad I managed to help you! And if I didn't help the other users as well, I probably wouldn't have managed to help you solve this in a single day. Happy foaming! Bruno
January 17, 2012, 07:31 |
#13 |
Sandy Lee
Rep Power: 18 |
Hi Bruno,
When I typed " paraFoam" in my user folder, I got error messanges as follows: FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake Do you know why? I followed above commons to do step by step, however, I can not still get success. Please help me out. Sandy |
January 17, 2012, 15:08 |
#14 |
Bruno Santos
Rep Power: 128 |
Hi Sandy,
Please state which OpenFOAM version you are using and in which Linux distribution. Also knowing which specific instructions you followed can make it easier for me to help you! Best regards, Bruno
[OpenFOAM] How to view openfoam results in paraview | Marineboy | ParaView | 9 | June 19, 2019 21:16 |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 08:33 |
OpenFOAM on non-English Ubuntu distribution | fabian_roesler | OpenFOAM | 3 | January 11, 2010 07:16 |
Installing OpenFOAM without Paraview | quartzian | OpenFOAM Installation | 0 | September 8, 2008 09:29 |
Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 12:59 |
