February 21, 2012, 12:14 |
R.e openFoam 1.6
Rep Power: 14 |
I'm currently trying to install openFoam 1.6 using these instructions: http://www.tfd.chalmers.se/~hani/kur...OwnLaptop.html It all worked fine except the paraview installation, I installed it instead through sudo apt get is there a way to link paraview and paraFoam? Regards Adam Thurlow |
February 21, 2012, 15:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Adam,
First detail: it is 1.6-ext, not simply 1.6! There is a very big difference Second: the ParaView version that comes with Ubuntu 10.04 is very old. You can get the one from openfoam.org - http://www.openfoam.org/download/ubuntu.php - namely the package "paraviewopenfoam3120" and then hack a bit on 1.6-ext:
Keep in mind that I haven't tested these instructions myself. This is basically an incomplete hack, since it only gets things half done. For several more detailed instructions, check my signature link Best regards, Bruno
February 22, 2012, 07:27 |
Rep Power: 14 |
Cheers that worked,
Updating OpenFOAm 1.6 to 2.0 | fs82 | OpenFOAM | 1 | May 3, 2012 09:19 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results | Arnoldinho | OpenFOAM Community Contributions | 7 | December 9, 2010 16:29 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
