yadavmahe |
February 1, 2012 04:11 |
Open Foam 1.7.x Installation on Altix Ice 8400 with Intel 12.1 compilers
I have been struggling trying to compile OpenFOAM 1.7.x on SGI altix ICE system with intel 12.1 compilers.
am using tcsh shell
and compilers are
intel 12.1
gcc-4.3.4
changed cshrc file Gcc to Icc
# Compiler: set to Gcc, Gcc43, Gcc44 or Icc (for Intel's icc)
if ( ! $?WM_COMPILER ) setenv WM_COMPILER Icc
And also changed rules of wmake
wmake/linux64Icc/cOpt and c++Opt
in cOpt file : cOPT = -O3 -no-prec-div -xSSE4.2 -ipo
in c++Opt file : c++OPT = -O3 -no-prec-div -xSSE4.2 -ipo
i added some flags -xSSE4.2 -ipo
after those chages, compiled as
./Allwmake
-- It taking more time
here some errors am getting
SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/1.7.x/' -e 's/BUILD_STRING/1.7.x/' $SOURCE > Make/linux64IccDPOpt/global.C; icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -O3 -no-prec-div -xSSE4.2 -ipo -DNoRepository -I/lustre/scratch/train2/apps/OpenFOAM/ThirdParty-1.7.x/zlib-1.2.3 -IlnInclude -I. -I/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude -I/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64IccDPOpt/global.C -o Make/linux64IccDPOpt/global.o
lnInclude/pTraits.H(71): warning #597: "Foam::pTraits<PrimitiveType>::operator Foam::vector() const [with PrimitiveType=Foam::vector]" will not be called for implicit or explicit conversions
operator PrimitiveType() const
detected during:
instantiation of class "Foam::pTraits<PrimitiveType> [with PrimitiveType=Foam::vector]" at line 87 of "lnInclude/Field.H"
instantiation of class "Foam::Field<Type> [with Type=Foam::vector]" at line 146 of "lnInclude/edgeI.H"
compilation aborted for derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.C (code 2)
make: *** [Make/linux64IccDPOpt/turbulentHeatFluxTemperatureFvPatchScalarField.o] Error 2
ld: cannot find -lcompressibleRASModels
make: *** [/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/lib/linux64IccDPOpt/liblagrangianIntermediate.so] Error 1
make[2]: *** [/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64IccDPOpt/dieselEngineFoam] Error 1
make[2]: Leaving directory `/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/applications/solvers/combustion/dieselEngineFoam'
make[1]: *** [dieselEngineFoam] Error 2
ld: cannot find -ldieselSpray
make[2]: *** [/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64IccDPOpt/foamDebugSwitches] Error 1
make[2]: Leaving directory `/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/applications/utilities/miscellaneous/foamDebugSwitches'
make[1]: *** [foamDebugSwitches] Error 2
MASTER.h(527): catastrophic error: cannot open source file "X11/Intrinsic.h"
# include <X11/Intrinsic.h>
compilation aborted for alloc.cpp (code 4)
make[3]: *** [Make/linux64IccDPOpt/alloc.o] Error 4
SOURCE=arrlist.cpp ; icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -O3 -no-prec-div -xSSE4.2 -ipo -DNoRepository -DMAKEARCHIVE -DLINUX -DLINUX64 -DUSEENUM -DTHREED -U_WIN32 -IlnInclude -I. -I/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude -I/lustre/scratch/train2/apps/OpenFOAM/OpenFOAM-1.7.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/arrlist.o
