December 6, 2012, 11:18 |
an error in new groovyBC
Ehsan
Rep Power: 26 |
I just compiled new groovyBC 0.2.1 and this error is shown,whats the cause?
Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> --> FOAM Warning : From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C at line 262 Reading "/home/ehsan/Desktop/thesis_Central/0/p::boundaryField::left" from line 30 to line 64 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 59 the string "((0<=time()&&time()<=(y_max-pos().y)/vel_r)||(time_1<=time()&&time()<=time_2)||(time_2< =time()&&time()<=(y_max-pos().y)/vel_r+time_2)||(time_3<=time()&&time()<=time_final ))?0:1" file: /home/ehsan/Desktop/thesis_Central/0/p::boundaryField::left::valueFraction at line 59. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 91. FOAM exiting |
December 6, 2012, 11:41 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
December 6, 2012, 12:09 |
Ehsan
Rep Power: 26 |
I want when time is in proper value BC be value if not be gradient how should I do this except at valuFraction?
December 6, 2012, 12:14 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The frequency of your questions suggests to me that instead of reading documentation (an there is not THAT much) you prefer asking. Problem with that approach is that people may have stopped answering your questions once you come to the parts that are not in the documentation
December 6, 2012, 12:34 |
Ehsan
Rep Power: 26 |
oh there is not something like valueFraction the correct keyword name is fractionExpression.I dont know how this mistake has occured in writing although I have read document several times. however thanks.
Display Modes | |
[swak4Foam] groovyBC for oscillatory flow | liybzd | OpenFOAM Community Contributions | 5 | November 12, 2018 07:53 |
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC | zanilu70 | OpenFOAM Community Contributions | 4 | December 13, 2016 06:46 |
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam | dani2702 | OpenFOAM Community Contributions | 0 | November 17, 2016 03:30 |
[swak4Foam] groovyBC issue - k and epsilon | sagnikmazumdar | OpenFOAM Community Contributions | 24 | March 1, 2015 07:16 |
[swak4Foam] groovyBC and Eqn.setReference() | benk | OpenFOAM Community Contributions | 3 | June 2, 2011 08:49 |
