libOSSpecific.o does not compile on Arch Linux |
April 17, 2012, 05:04 |
Robert Sawko
Rep Power: 22 |
Dear All,
I have compiled OpenFOAM from sources on Arch Linux. However, I had a small issue and I have little confidence in the workaround I have applied. After the first compilation I had many errors of the following type: Code:
/usr/bin/ld: cannot find -lOpenFOAM After applying wmake on certain directories I figured out that libOSSpecific.o was missing. What I did eventually was to copy this file from my "working" OF distribution into $FOAM_LIBBIN. The previous file was compiled on the same machine but on a different system. My question is why did I have to do it? Why libOSSpecific.H did not compile? Is it a missing dependency? If you could provide me with some hints or references. I am a little worried that I copied an OS specific file from a different system to work on my current system. |
April 17, 2012, 05:07 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Robert,
Apparently you're having the same problem described here: http://www.cfd-online.com/Forums/ope...oam-2-1-x.html Best regards, Bruno
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 | gwierink | OpenFOAM Installation | 0 | April 5, 2011 04:38 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
PV3FoamReader compile error.... | PEM_GUY | OpenFOAM Installation | 6 | April 5, 2010 17:22 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 05:41 |
