[blockMesh] Meshing a disc like this
Old   May 7, 2012, 04:43
Smile Meshing a disc like this
m_r
Marine
m_r is on a distinguished road
Hello everyone !
I'm a new user of OpenFOAM and I wish realise a mesh of this type, but i don't really know how to do it :
Somebody can help me to start ?
I have understood how to mesh differents types of cubes (such as with an arc of circle) but i have no idea for start to mesh a circle/a disc.
Thank you (and sorry for my bad english )
Marine
m_r is offline   Reply With Quote
Old   May 7, 2012, 04:53
romant's Avatar
Roman Thiele
romant is on a distinguished road
I don't think you will be able to mesh this with blockMesh, because blockmesh will create hexahedral cells, however exactly at the center you have tetrahedral cells. the easiest way to create such a disc is to make a block in the center and then create quarter circle blocks on every side.
~roman
romant is offline   Reply With Quote
Old   May 7, 2012, 05:10
m_r
Marine
Thank for your rapid answer.
If I understood correctly,, your idea is to create a central block then create many quarter circle block around.
You think it's possible to realise a maillage like this with four blocks and create arcs of circle inside the blocks ?
Old   May 7, 2012, 05:20
romant's Avatar
Roman Thiele
I think the following can help you. You can create arc also on the inside of the block, but you won't have a disc then, but a ring, which has just a very small hole in the center. 5 blocks (1 center block, 4 blocks on the outside, where the ones on the outside have arcs as boundaries) is the standard to create round objects with hexahedral cells.
http://www.cfd-online.com/Forums/ope...arge-mesh.html
~roman
Old   May 7, 2012, 05:26
m_r
Marine
Thank, I studying your link and then, after, I try to meshing a disc.
Old   May 7, 2012, 08:08
Ivanet is on a distinguished road
It is possible and even very easy to do it with blockMesh.
You can check for example this link
http://www.somogyibence.hu/documents...sh_O-Grid.html
for learning about how to work with blockMesh.
Greetings
Ivan
Ivanet is offline   Reply With Quote
Old   May 7, 2012, 08:50
m_r
Marine
Thank you so much Ivan.
Old   July 18, 2012, 14:52
Nikunj Raithatha
Nikunj.R is on a distinguished road
1.Divide the circle in 4 quadrants, assume the point (0,0,0) to be at the center of the disc.
2.find the coordinates of all the vertices of the quadrants relative to this point. (eg: (5,0,0) (0,5,0) (-5,0,0) (0,-5,0).
3. specify the same vertices for say z=10
4.specify that edges 0-1. 1-2, et al are arcs, while following the correct syntax.
5.form the block.
6. give "empty" bc for faces at z=10, z=-10.
Nikunj.R is offline   Reply With Quote
Conjugate heat transfer of ventilated disc brake Aakashi123 CFX 3 January 30, 2017 01:41
[ANSYS Meshing] Icem meshing queries Mfaizan ANSYS Meshing & Geometry 21 July 30, 2015 23:10
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
