[blockMesh] Skewness Problems
Like Tree2Likes
  • 1 Post By lucasw7
  • 1 Post By Antimony
Old   December 3, 2012, 01:20
Default Skewness Problems
Lucas
lucasw7 is on a distinguished road
Hi, I'm a relatively new OF user - this issue probably has been addressed a number of times.
For a simple internal flow problem from one opening through to another, I am unable to begin solving using SimpleFoam. Blockmeshdict and the checkMesh are shown below. I just want to know how one would go about fixing the errors shown in the mesh check in order to run the solver? If you run blockMesh and view the wireframe in paraview, you'll see that the geometry is split up into 3 quadrilaterals - two rectangles and a trapezium. I assume the trapezium shaped section is the cause of the problem due to the largely skewed cells. Can anyone come up with a quick solution to fix this?
Thanks!
Lucas
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0) //0
(-5 -5 0) //1
(5 -15 0) //2
(10 -10 0) //3
(0 0 4) //4
(-5 -5 4) //5
(5 -15 4) //6
(10 -10 4) //7
(0 0 0) //8
(10 -10 0) //9
(20 -10 0) //10
(20 0 0) //11
(0 0 4) //12
(10 -10 4) //13
(20 -10 4) //14
(20 0 4) //15
(0 0 0) //16
(20 0 0) //17
(20 5 0) //18
(0 5 0) //19
(0 0 4) //20
(20 0 4) //21
(20 5 4) //22
(0 5 4) //23
(20 -5 0) //24
(20 -3 0) //25
(20 -5 3) //26
(20 -3 3) //27
(20 -5 0) //28
(20 -3 0) //29
(20 -5 3) //30
(20 -3 3) //31
(17 -10 0) //32
(18.5 -10 0) //33
(17 -10 3) //34
(18.5 -10 3) //35
(17 -10 0) //36
(18.5 -10 0) //37
(17 -10 3) //38
(18.5 -10 3) //39
(10 0 0) //40
(10 0 3) //41
(10 0 0) //42
(10 0 3) //43
blocks
hex (0 1 2 3 4 5 6 7) (50 100 40) simpleGrading (1 1 1)
hex (8 9 10 11 12 13 14 15) (100 200 40) simpleGrading (1 1 1)
hex (16 17 18 19 20 21 22 23) (200 50 40) simpleGrading (1 1 1)
hex (32 33 37 36 34 35 39 38) (15 1 30) simpleGrading (1 1 1)
hex (24 25 29 28 26 27 31 30) (20 1 30) simpleGrading (1 1 1)
edges
patches
wall upper
(0 1 2 3)
(8 9 10 11)
(16 17 18 19)
wall lower
(4 7 6 5)
(12 15 14 13)
(20 23 22 21)
wall sides
(1 5 6 2)
(3 2 6 7)
(1 0 4 5)
(11 10 14 15)
(16 19 23 20)
(19 18 22 23)
patch door1
(32 33 35 34)
(36 37 39 38)
patch inlet
(10 9 13 14)
(24 25 27 26)
(28 29 31 30)
patch outlet
(18 17 21 22)
mergePatchPairs
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 4267115
internal faces: 4139005
cells: 1401050
boundary patches: 6
point zones: 4
face zones: 12
cell zones: 0
Overall number of cells of each type:
hexahedra: 1400870
prisms: 164
wedges: 8
pyramids: 0
tet wedges: 8
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
*Number of regions: 5
The mesh has multiple regions which are not connected by any face.
<<Writing region information to "0/cellToRegion"
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
upper 35000 35703 ok (non-closed singly connected)
lower 35000 35703 ok (non-closed singly connected)
sides 22000 22673 ok (non-closed singly connected)
inlet 8000 8241 ok (non-closed singly connected)
outlet 2000 2091 ok (non-closed singly connected)
defaultFaces 26110 26833 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-5 -15 0) (20 5 4)
Mesh (non-empty, non-wedge) directions (0 0 1)
Mesh (non-empty) directions (0 0 1)
***Number of edges not aligned with or perpendicular to non-empty directions: 1236150
<<Writing 1039391 points on non-aligned edges to set nonAlignedEdges
Boundary openness (1.68712e-17 -1.16793e-15 1.93548e-14) OK.
Max cell openness = 2.44327e-16 OK.
Max aspect ratio = 1 OK.
***Zero or negative face area detected. Minimum area: 0
<<Writing 2015 zero area faces to set zeroAreaFaces
Min volume = 1.33333e-300. Max volume = 0.0444444. Total volume = 1432.33. Cell volumes OK.
Mesh non-orthogonality Max: 90 average: 17.4404
***Number of non-orthogonality errors: 2005.
<<Writing 2005 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 1042 faces are incorrectly oriented.
<<Writing 1042 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 57.5098, 1068 highly skew faces detected which may impair the quality of the results
<<Writing 1068 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 5 mesh checks.
End
lucasw7 is offline   Reply With Quote
Old   December 3, 2012, 04:11
Doug68 is on a distinguished road
Sorry I dont have the exact syntax to hand, but what you need to do is use the FoamToVTK function to get a VTK file of the skewed faces.
Then you can open the VTK file and the mesh in Paraview.
From there you should be able to identify where the skewed surfaces are and do something with the geometry so that the faces don't get skewed when being meshed.
Doug68 is offline   Reply With Quote
Old   December 3, 2012, 23:05
Lucas
Thanks for the advice, however I was able to view the mesh in paraview as blockMesh worked, - it's the solver which won't start due to the skewed mesh. I'm just stuck on how to fix the geometry in order for it to work, anyone got any tips?
Yemi2favours likes this.
Old   December 4, 2012, 02:58
The point to my original post was, you need to modify your mesh so that the skew faces do not exist in the first place. Then you should be able to get the solver to run.
Without knowing where the skewness exists in your geometry you are going to be hard pushed to know how to modify it to get rid of it. Hence this is why I gave the advice so you should be able to visualize the location of the skewed faces.
Old   December 21, 2016, 19:58
Ken
kennyboy is on a distinguished road
what's the exact syntax you used for the skewfaces? i tried faceset and cellset but they dont worl.
kennyboy is offline   Reply With Quote
Old   December 22, 2016, 01:20
Antimony is on a distinguished road
I believe it should be: foamToVTK -faceSet skewFaces -ascii
The ASCII option may not be needed, but I prefer to put it as long as the file size isn't huge.
Cheers,
Antimony
Milan Shrestha likes this.
Antimony is offline   Reply With Quote
Old   July 11, 2019, 00:52
Default Thanks
Milan
Milan Shrestha is on a distinguished road
Originally Posted by Antimony View Post
Cheers,
Antimony
Thank you for your support.
Milan Shrestha is offline   Reply With Quote
check mesh, skewness
[ANSYS Meshing] Fluent Meshing results in very high skewness FFD ANSYS Meshing & Geometry 10 August 31, 2017 11:09
URANS 2D Square Cylinder Problems and_user OpenFOAM Running, Solving & CFD 5 May 24, 2017 21:01
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
[GAMBIT] Meshing problems iHal ANSYS Meshing & Geometry 6 February 25, 2010 08:21
SimpleFoam problems with converging maybe skewness hoochie OpenFOAM Running, Solving & CFD 4 May 14, 2007 07:23
