[mesh manipulation] cellSet - how to define a hollow cylinder
Like Tree1Likes
  • 1 Post By RugbyGandalf
Old   December 13, 2012, 05:11
Default cellSet - how to define a hollow cylinder
Martin
RugbyGandalf is on a distinguished road
Dear community,
i am facing the following problem:
I want to define three regions of a pipe, using cellSet and cellZoneSet. But after applying cylinderToCell for the outer region and doing the same (with smaller radius) for the middle region, the outer region won't reduce its cellsize. This leads to the problem, that the middle cells show up in the first cellSet, but in the second one as well. As a result, splitMeshRegions fails.
To make it clear, please have a look at my sketch and my topoSetDict.
actions
        name    R1;
        type    cellSet;
        action  new;
        source  cylinderToCell;
        sourceInfo
            p1 (0 0 -0.009950000000000001);
            p2 (0 0 -0.0014);
            radius 0.00291666613;
        name    R2;
        type    cellSet;
        action  new;
        sourceInfo
        p2 (0 0 -0.0014);
        radius 0.0021;
I am hoping for some help.
Regards,
Martin
RugbyGandalf is offline   Reply With Quote
Old   December 15, 2012, 12:54
Retired Super Moderator
Bruno Santos
Greetings Martin,
Might I suggest you share an example case ready for testing? Even if not of a cylinder, perhaps of a cube?
As for your description:
[...] the outer region won't reduce its cellsize.
Do you mean "cell size" or "cell count"??
Best regards,
Bruno
Old   December 17, 2012, 02:34
Martin
Dear Bruno,
thank you for your repeat.
I meant, that the number of cells is not decreasing, when applying the second action (for R2), but stays the same.
However, I figured out, how to solve this problem.
If someone faces the same problem, please have a look at the following code:
actions
name R1;
type cellSet;
action new;
sourceInfo
p2 (0 0 -0.0014);
name R1;
type cellSet;
action delete;
sourceInfo
p2 (0 0 -0.0014);
radius 0.0021;
name R2;
type cellSet;
action new;
sourceInfo
p2 (0 0 -0.0014);
radius 0.0021;
franciscofelis likes this.
Induction heating of hollow cylinder cfd.geek FLUENT 1 August 12, 2022 16:38
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
An odd ERROR mdakbari Fluent UDF and Scheme Programming 7 April 4, 2016 04:30
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
