blockMesh error
I get the following errors when trying to blockMesh... ...the tutorial case "bubbleColumn": Code:
fileName::stripInvalid() called for invalid fileName /home/USER/OpenFOAMTutorials/run/tutorials/multiphase/multiphaseEulerFoam/bubbleColumn Code:
--> FOAM FATAL IO ERROR: greetings maybee |
Which bubbleColumn tutorial? There are multiple. I tested for 2.2.0, and there they all worked properly.
Ok solved it for my own case "MyCase" with help of thread:
http://www.cfd-online.com/Forums/ope...tml#post482234 I just had one bracket too much. Thx. anyway :). |
