June 19, 2014, 04:17 |
meshing a big room
zohreh imani nejad
Rep Power: 12 |
hi
who can help me what is this error... Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00995599, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0104898, No Iterations 1 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 0.0591834, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 7.1898, No Iterations 1001 time step continuity errors : sum local = 84.0209, global = 0.0235848, cumulative = 0.0235848 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #5 at kEpsilon.C:0 #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #7 in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/buoyantBoussinesqSimpleFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/buoyantBoussinesqSimpleFoam" Floating point exception (core dumped) i think my problem is that my mesh is very big....because my room is very large ,when i fine my meshs it can not make blockMesh successfully what should i do thanks alot |
June 19, 2014, 08:17 |
Lieven
Rep Power: 22 |
Hi imani,
What do you mean exactly when you say "my mesh is very big". Do you mean a large number of cells or very big dimensions? Can you post the output of checkMesh? Regarding the error you get, there is a division by zero somewhere in the run. Since you are using the kEpsilon model, my first guess will be that epsilon is set to 0 in your initial conditions. Set it to any other positive value (but best is to make it small, 1e-3 or so). Which solver are you using? Just asking since your pressure equation is messed up... Cheers, Lieven |
June 19, 2014, 08:30 |
zohreh imani nejad
Rep Power: 12 |
hi dear
my dimension is a room 8*6*2.7 meter this room has windows with gap these gap are 2 mm and around the windows when i fine my meshes i have problem my solver is buoyantBossinesqueSimpleFoam |
June 19, 2014, 16:43 |
Lieven
Rep Power: 22 |
Hi Imani,
Did you try to modify the epsilon-initial conditions? Could you please give the output of checkMesh? At the moment, you really didn't give enough to be able to help you properly... |
June 21, 2014, 01:10 |
zohreh imani nejad
Rep Power: 12 |
hi dear lieven
thank you /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : checkMesh Date : Jun 21 2014 Time : 08:24:10 Host : "ubuntu" PID : 2679 Case : /home/dell/Desktop/zohreh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 139468 faces: 398460 internal faces: 379140 cells: 129600 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 129600 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology fixedWall-1 1620 1708 ok (non-closed singly connected) fixedWall-2 2160 2268 ok (non-closed singly connected) fixedWall-3 1620 1736 ok (non-closed singly connected) fixedWall-4 2160 2268 ok (non-closed singly connected) floor 4800 4981 ok (non-closed singly connected) ceiling 4800 4981 ok (non-closed singly connected) defaultFaces 2160 2268 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 0) (8 2.7 6) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (2.80429e-16 7.81092e-16 5.17203e-16) OK. Max cell openness = 1.66463e-16 OK. Max aspect ratio = 1.44416 OK. Minumum face area = 0.00479307. Maximum face area = 0.0191723. Face area magnitudes OK. Min volume = 0.000479307. Max volume = 0.00191723. Total volume = 129.6. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 5.2182e-12 OK. Coupled point location match (average 0) OK. Mesh OK. End dell@ubuntu:~/Desktop/zohreh$ buoyantBoussinesqSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : buoyantBoussinesqSimpleFoam Date : Jun 21 2014 Time : 08:24:20 Host : "ubuntu" PID : 2680 Case : /home/dell/Desktop/zohreh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading thermophysical properties Reading field T Reading field p_rgh Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Creating turbulence model Selecting RAS turbulence model kEpsilon --> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 119 No value defined for k on fixedWall-4 therefore using 2160{0} bounding k, min: 0 max: 0.1 average: 0.1 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Reading field kappat Calculating field g.h SIMPLE: convergence criteria field p_rgh tolerance 0.01 field U tolerance 0.0001 field T tolerance 0.01 field "(k|epsilon|omega)" tolerance 0.001 Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00995599, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0104898, No Iterations 1 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 0.0591834, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 7.1898, No Iterations 1001 time step continuity errors : sum local = 84.0209, global = 0.0235848, cumulative = 0.0235848 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #5 at kEpsilon.C:0 #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #7 in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/buoyantBoussinesqSimpleFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/home/dell/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/buoyantBoussinesqSimpleFoam" Floating point exception (core dumped) dell@ubuntu:~/Desktop/zohreh$ have good day imani |
[ANSYS Meshing] 2D Meshing of Parallel Airfoils | Fco.Herbert | ANSYS Meshing & Geometry | 1 | December 5, 2017 15:42 |
[ANSYS Meshing] Can start ANSYS meshing only one time on ubuntu 16.04 | Touré | ANSYS Meshing & Geometry | 2 | September 26, 2017 05:41 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
