[snappyHexMesh] Problem with Sanpper, surface still Rough |
October 29, 2014, 06:19 |
Francesco
Rep Power: 11 |
Hi, i'm a new OpenFOAM user end i have some trouble meshing an airplane with snappyHexMesh, the problem is the same if i try to mesh a single part (like the canard).
The surface is not smooth but remain rough like a golf ball, LE and TE are the most affected part. The stl file is smooth and doesn't have any problem. Someone can help me? I want also to know wich parameter in the snappyHexMesh Dict i have to change to improove the performance of the mesh, some comand are unclear, like the relative tolerance or the feature angle.. Code:
*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { LiMoRANS.stl { type triSurfaceMesh; name LiMoRANS; } refinementBox { type searchableBox; min (-10.0 -10 -3); max ( 10 5 3); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 1000000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 8000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 50; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 4; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "LiMoRANS.eMesh"; level 6; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { LiMoRANS { // Surface-wise min and max refinement level level (4 5); // Optional specification of patch type (default is wall). No // constraint types (cyclic, symmetry) etc. are allowed. patchInfo { type wall; inGroups (LiMoRANSGroup); } } } // Resolve sharp angles resolveFeatureAngle 90; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { refinementBox { mode outside; levels ((1E13 4)); } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0 0 -2); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 60; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 1.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 8; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 30; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { "(lowerWall|motorBike).*" { nSurfaceLayers 1; } } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the // thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. finalLayerThickness 0.3; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 3; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" // Advanced //- Number of error distribution iterations nSmoothScale 4; //- amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Write flags writeFlags ( layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // |
October 29, 2014, 06:41 |
Julian Langowski
Rep Power: 14 |
Hi Zephiro,
got any images of the problem? I suggest, try to increase snapping refinement Code:
level (4 5) Code:
level (4 6) There is a lot of other possibilites, but without clear description of the problem it is hard to help. Best regards Julian
πάντα ῥεῖ - Heraclitus |
October 29, 2014, 09:03 |
Francesco
Rep Power: 11 |
Ok, this is a screenshot of the meshed canard. I hope it's enough to understand what is the problem.
In the SHM dict i have post above there is an error, the refinment region in the correct dict is set Inside.. My pc have 8GB of RAM and i7 8core processor. Sorry if i don't write wery well but I'm not english.. |
November 5, 2014, 07:30 |
Francesco
Rep Power: 11 |
I have increase the snapping refinment to (4 8) but the result is the same.
November 5, 2014, 08:36 |
Albrecht vBoetticher
Rep Power: 16 |
Hi Francesco,
How do you generate your .eMesh? There is the key for right edge snapping. // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { //for better snapping file " LiMoRANS.eMesh"; levels ((0.0 2) (0.002 1)); } ); So to find options that may help, try surfaceFeatureExtract -help |
November 5, 2014, 10:18 |
Francesco
Rep Power: 11 |
This is the SurfaceFeature extract dict that i use:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object surfaceFeatureExtractDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // LiMoRANS.stl { // How to obtain raw features (extractFromFile || extractFromSurface) extractionMethod extractFromSurface; extractFromSurfaceCoeffs { // Mark edges whose adjacent surface normals are at an angle less // than includedAngle as features // - 0 : selects no edges // - 180: selects all edges includedAngle 180; } subsetFeatures { // Keep nonManifold edges (edges with >2 connected faces) nonManifoldEdges no; // Keep open edges (edges with 1 connected face) openEdges no; } // Write options // Write features to obj format for postprocessing writeObj yes; } // ************************************************************************* // |
November 5, 2014, 10:30 |
Francesco
Rep Power: 11 |
I try to set the explicit edge refiniment to the value that you suggest but the result is an error message
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : snappyHexMesh -parallel -overwrite Date : Nov 05 2014 Time : 15:23:55 Host : "ubuntu" PID : 3109 Case : /home/francesco/OpenFOAM/francesco-2.3.0/run/LiMo/LiMoRANSCanard nProcs : 8 Slaves : 7 ( "ubuntu.3110" "ubuntu.3111" "ubuntu.3112" "ubuntu.3113" "ubuntu.3114" "ubuntu.3115" "ubuntu.3116" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.02 s Overall mesh bounding box : (-20 -25 -10) (20 5 10) Relative tolerance : 1e-06 Absolute matching distance : 5.38516e-05 Reading refinement surfaces. Read refinement surfaces in = 0.02 s Reading refinement shells. Refinement level 2 for all cells inside refinementBox Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read edgeMesh LiMoRANS.eMesh points : 1203 edges : 3597 boundingBox : (-8.09 -1.96649 -0.0834526) (8.09 0.540291 0.176185) [1] [1] [1] --> FOAM FATAL IO ERROR: [1] [2] [2] [2] --> FOAM FATAL IO ERROR: [2] wrong token type - expected int, found on line 0 the punctuation token '(' [2] [3] [3] [3] --> FOAM FATAL IO ERROR: [3] wrong token type - expected int, found on line 0 the punctuation token '(' [3] [3] [4] [4] [4] --> FOAM FATAL IO ERROR: [4] wrong token type - expected int, found on line 0 the punctuation token '(' [4] [4] file: IOstream.castellatedMeshControls.features.level at line 0. [4] [6] [6] [6] --> FOAM FATAL IO ERROR: [6] wrong token type - expected int, found on line 0 the punctuation token '(' [6] [6] file: IOstream.castellatedMeshControls.features.level at line 0. [6] [6] From function operator>>(Istream&, int&)[7] [7] [7] --> FOAM FATAL IO ERROR: [7] wrong token type - expected int, found on line 0 the punctuation token '(' [7] [7] file: IOstream.castellatedMeshControls.features.level at line 0. [7] [7] [0] [0] [0] --> FOAM FATAL IO ERROR: [0] wrong token type - expected int, found on line 95 the punctuation token '(' [0] [0] file: /home/francesco/OpenFOAM/francesco-2.3.0/run/LiMo/LiMoRANSCanard/system/snappyHexMeshDict.castellatedMeshControls.features.level at line 95. [0] [0] From function operator>>(Istream&, int&) [0] in file primitives/ints/int/intIO.C at line 68.wrong token type - expected int, found on line 0 the punctuation token '(' [1] [1] file: IOstream.castellatedMeshControls.features.level at line 0. [1] [1] From function operator>>(Istream&, int&) [1] in file primitives/ints/int/intIO.C at line 68. [1] FOAM parallel run exiting [1] [2] file: IOstream.castellatedMeshControls.features.level at line 0. [2] [2] From function operator>>(Istream&, int&) [2] in file primitives/ints/int/intIO.C at line 68. [2] FOAM parallel run exiting [2] file: IOstream.castellatedMeshControls.features.level at line 0. [3] [3] From function operator>>(Istream&, int&) [3] in file primitives/ints/int/intIO.C at line 68. [3] FOAM parallel run exiting [3] [4] From function operator>>(Istream&, int&) [4] in file primitives/ints/int/intIO.C at line 68. [4] FOAM parallel run exiting [4] [6] in file primitives/ints/int/intIO.C at line 68. [6] FOAM parallel run exiting [6] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 7 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- From function operator>>(Istream&, int&) [7] in file primitives/ints/int/intIO.C at line 68. [7] FOAM parallel run exiting [7] [0] FOAM parallel run exiting [0] [5] [5] [5] --> FOAM FATAL IO ERROR: [5] wrong token type - expected int, found on line 0 the punctuation token '(' [5] [5] file: IOstream.castellatedMeshControls.features.level at line 0. [5] [5] From function operator>>(Istream&, int&) [5] in file primitives/ints/int/intIO.C at line 68. [5] FOAM parallel run exiting [5] -------------------------------------------------------------------------- mpirun has exited due to process rank 6 with PID 3115 on node ubuntu exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [ubuntu:03108] 7 more processes have sent help message help-mpi-api.txt / mpi-abort [ubuntu:03108] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
November 5, 2014, 13:05 |
Rep Power: 16 |
Sorry, my mistake. One can define how many times cells should be splitted at the edges using levels, the levels specification I copied was from refinementRegions mode distance and does not belong there. You run OpenFOAM 2.3 right? Maybe you can try setting the feature angle to 179 due to this thread: http://www.cfd-online.com/Forums/ope...ain-edges.html
Display Modes | |
yPlus values for atmospheric boundary layer over complex terrain with rough surface | Mojtaba.a | OpenFOAM Running, Solving & CFD | 7 | March 30, 2017 16:15 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
Strange results for rough surface | camoesas | CFX | 3 | June 14, 2010 19:30 |
surface orentation problem in icemcfd | jeevan kumar | CFX | 0 | August 18, 2008 05:25 |
Surface orentation problem in icemcfd | jeevan kumar | CFX | 0 | August 13, 2008 02:54 |
