November 13, 2014, 01:57 |
getting unwanted internal faces
Arjun
Rep Power: 12 |
Dear all,
I am new to blockMesh utility. I have attached my domain with corresponding vertices numbering. I want to divide my domain in to four as marked in the figure. for that following codes are used: hex(0 1 2 8 10 11 12 18) (10 10 1) simpleGrading (1 1 1) //block 0 hex(8 2 3 7 18 12 13 17) (10 10 1) simpleGrading (1 1 1) //block 1 hex(7 9 5 6 17 19 15 16) (10 10 1) simpleGrading (1 1 1) //block 2 hex(9 3 4 5 19 13 14 15) (10 10 1) simpleGrading (1 1 1) //block 3 But i am getting two internal face, its orientation is (7 17 9 19) and (9 19 3 13) I want to get rid of this internal face. Or help me with any other condition that will nullify the effect of internal face. DSC_1749.jpg Last edited by Arjun Jayakumar; November 13, 2014 at 03:52. |
November 13, 2014, 04:19 |
#2 | |
Anyways, try defining your Boundary Conditions like this, defaultFaces { type empty; } Re-run your case, I hope it will solve your problem. - Best Luck! |
November 13, 2014, 05:02 |
#3 | |
Arjun
Rep Power: 12 |
thank you for your time. I have already tried this by setting the defaultfaces to empty but this will not help to solve the problem. Its showing higher velocities at the patch surface, which result in too high courant number. Do you know how i am getting these internal faces, without defining any where in the blockMesh dictionary. |
November 13, 2014, 05:34 |
#4 | |
The error is in the blockMesh, due to node (9, 19) which is connected to a face. If you remove this node and use only 3 blocks it will work, as it will follows the block rule. If your case demands such mesh only. Then, you can try "merge" option of OpenFOAM. Although, I never tried it but I think that will help you resolve. Please, do share to FOAM community if you happen to get correct solutions. - Best Luck! |
November 13, 2014, 06:36 |
#5 | |
Arjun
Rep Power: 12 |
I need to define a patch on face (4 14 15 5). If i try with 3 blocks it will lead to error "face 0 in patch 0 does not have neighbour cell face: 4(4 14 15 5). I am not familiar with merge. which all faces do you suggest to merge. Thank you |
November 13, 2014, 07:20 |
#6 | |
You can easily construct 3 block for the case which you have referred in the figure. Follow carefully the blockMesh strategy of OpenFOAM, refer link below for the same: http://www.openfoam.org/docs/user/blockMesh.php For merge patch I am not an expert. You can explore it. - Best Luck! |
November 13, 2014, 14:03 |
Marco A. Turcios
Rep Power: 28 |
An alternative method is to generate the 3-block mesh which works, then use topoSet to select the faces that correspond to face 4 14 15 5 and use createPatch to generate the boundary patch.
I've found this approach is more consistent and allows you to make all kinds of boundary patches that only partially cover the domain boundaries, and requires less debugging of the blockMesh dict file which can become a real headache. |
November 14, 2014, 06:48 |
#8 | |
Arjun
Rep Power: 12 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
[blockMesh] Difficulty creating internal faces | salomama | OpenFOAM Meshing & Mesh Conversion | 1 | August 19, 2018 15:45 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
