[snappyHexMesh] SHM Problems with snapping and layers |
April 14, 2016, 13:52 |
Ruggiero Guida
Rep Power: 12 |
Dear Foamers,
I am struggling to get continuous layers on the mesh in the attached file. (The only geometry is 'fixed_surroundings.stl') I am using OF 3.01 As you can see from a horizontal and vertical section the layers are not continuous. I have also noticed that if I keep my refinements for features and surfaces below 6 then SHM does not snap to the top-left vertical edge. The series of commands that I run is the following: Code:
foamCleanPolyMesh blockMesh surfaceFeatureExtract decomposePar mpirun -n 2 snappyHexMesh -parallel reconstructParMesh foamToVTK Any idea? |
[snappyHexMesh] Controlling y+ values with snappyHexMesh? | cjm | OpenFOAM Meshing & Mesh Conversion | 67 | July 10, 2019 18:56 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 16:45 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 01:56 |
[snappyHexMesh] Fail to create boundary layers during sHM | farahiam | OpenFOAM Meshing & Mesh Conversion | 13 | October 15, 2014 19:46 |
[snappyHexMesh] Effect of adding layers with sHM | Nucleophobe | OpenFOAM Meshing & Mesh Conversion | 4 | August 20, 2012 16:45 |
