[blockMesh] blockMesh warning negative volume
Old   January 13, 2015, 08:09
Default blockMesh warning negative volume
pizzaspinate is on a distinguished road
Hi guys,
I try to blockMesh my geometry but I get the following warnings when doing so:
FOAM Warning:
From function cellModel::mag (const labelList&, const pointField&)
in file meshes/meshShapes/cellModel/cellModel.c at line 128
zero or negative pyramid volume: -3.3333e+09 for face 1
FOAM Warning:
in file blockMesh/blockMeshTopology.C at line 255
negative volume block: 0, probably defined inside out
What is the reason for this?
Where can I find meshes/meshShapes/cellModel/cellModel.c and blockMesh/blockMeshTopology.C?
Thank you very much in advance for your help
Last edited by pizzaspinate; January 13, 2015 at 08:32. Reason: already solved problem
pizzaspinate is offline   Reply With Quote
Old   January 13, 2015, 08:30
Fatih Ertinaz
fertinaz is on a distinguished road
would you share your blockMeshDict?
fertinaz is offline   Reply With Quote
Old   January 13, 2015, 08:32
uuupss, realised my mistake and solved the problem :-)
Old   April 13, 2016, 10:11
Default Negative Valumes in BlockMesh
Maral Mohajer
MaralMohajer is on a distinguished road
Hii
What was your mistake ?
I'm facing same problem .
Regardss
Maral
MaralMohajer is offline   Reply With Quote
Old   May 15, 2016, 07:30
Antimony is on a distinguished road
Hi Maral,
Check the order in which you have defined your vertices and the way you have called them while defining the hex block.
As an example, assuming that you are creating a cuboid, the way I would define it is to start at the lower z value, from the bottom left point and continue in a anticlockwise way to the top left point. And then do the same for the higher z value.
I have noticed that this way allows you to avoid the inside out problem.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
