[blockMesh] BlockMesh zero or negative pyramid volume |
December 13, 2016, 05:25 |
Rep Power: 9 |
i'm trying to create a simple mesh (i'm just learning openFoam) shaped like a T upside-down. This is the blockMeshDict: Code:
convertToMeters 0.1; vertices ( (0 0 0) (20 0 0) (20 1 0) (0 1 0) (0 0 0.1 ) (20 0 0.1 ) (20 1 0.1 ) (0 1 0.1 ) (5 1 0) (6 1 0) (6 1 0.1) (5 1 0.1) (5 4 0) (6 4 0) (6 4 0.1) (5 4 0.1) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( top { type wall ; faces ( (3 7 11 8) (8 11 15 12) (14 10 9 13) (9 10 6 2) ); } bottom { type wall ; faces ( (1 5 4 0) ); } inlet1 { type patch ; faces ( (0 4 7 3) ); } inlet2 { type patch ; faces ( (12 15 14 13) ); } outlet { type patch ; faces ( (2 6 5 1) ); } frontAndBack { type empty ; faces ( (0 3 2 1) (4 5 6 7) ); } ); mergePatchPairs ( ); Code:
zero or negative pyramid volume: -0.05 for face 0 And also Code:
--> FOAM FATAL ERROR: face 0 in patch 0 does not have neighbour cell face: 4(3 7 11 8) Thanks |
December 13, 2016, 05:51 |
Rep Power: 9 |
I found one mistake in the order of the vertices.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) //0 (20 0 0) //1 (20 1 0) //2 (0 1 0) //3 (0 0 0.1 ) //4 (20 0 0.1 ) //5 (20 1 0.1 ) //6 (0 1 0.1 ) //7 (5 1 0) //8 (6 1 0) //9 (6 4 0) //10 (5 4 0) //11 (5 1 0.1) //12 (6 1 0.1) //13 (6 4 0.1) //14 (5 4 0.1) //15 ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( top { type wall ; faces ( (8 3 7 12) (8 12 15 11) (14 13 9 10) (9 13 6 2) ); } bottom { type wall ; faces ( (1 5 4 0) ); } inlet1 { type patch ; faces ( (0 4 7 3) ); } inlet2 { type patch ; faces ( (11 15 14 10) ); } outlet { type patch ; faces ( (2 6 5 1) ); } frontAndBack { type empty ; faces ( (0 3 2 1) (4 5 6 7) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
Create time Creating block mesh from "/home/marco/OpenFOAM/marco-4.1/run/prova/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM FATAL ERROR: face 0 in patch 0 does not have neighbour cell face: 4(8 3 7 12) From function Foam::labelList Foam::polyMesh::facePatchFaceCells(const faceList&, const labelListList&, const faceListList&, Foam::label) const in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 118. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::polyMesh::facePatchFaceCells(Foam::List<Foam::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const at ??:? #3 Foam::polyMesh::setTopology(Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:? #4 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:? #5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:? #6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Aborted |
December 14, 2016, 21:20 |
Rep Power: 15 |
In neither of your blocks do you have any surface that contains all the vertices 8, 3, 7 and 12. In order for you to define a boundary, the vertices should together be part of a block, which is not the case. Hope this helps. Cheers, Antimony |
December 15, 2016, 07:17 |
Rep Power: 9 |
i thought that blocks wouldn't need same vertices. Thanks |
February 18, 2017, 19:47 |
Rep Power: 9 |
Hey
Your Problem isn't the block or it's points, that seems to be right; your Problem is, that you are defining a face (of the wall "Top") over two blocks. that is just not possible. check your points and the faces you want to build, maybe write them down and draw your geometry and you will see, what you'll have to change. best regards |
blockmeshdict, error, warning message |
[ANSYS Meshing] Small mesh error: Zero or negative volume for elements. [Explicit dynamics] | matin | ANSYS Meshing & Geometry | 0 | September 14, 2017 20:19 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Courant number blowing up, non-orthogonal mesh? | odellar | OpenFOAM Running, Solving & CFD | 5 | October 22, 2013 19:50 |
Possible bug in blockMesh | benru | OpenFOAM Bugs | 16 | August 17, 2013 19:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
