Satyajit Choudhury
Rep Power: 3 ![]() |
I want to study the flow of blood through an artery having a bulge(aneurysm).
I intend to use openFoam for my simulation. So, how do I create a cylindrical geometry where the radius of the cylinder changes as a function(Gaussian function to be specific) of the axial distance. Is it possible to create such a geometry using blockMesh tool? If not, what software should I be using? Suggestions would be highly appreciated. Thank you. |
Kal-El
You can create the mesh with snappyHexMesh, but you need some other tool for geometry. Perhaps Solidworks or some other CAD-software?
Satyajit Choudhury
Thanks Kal-EI for the reply. I was able to make the mesh using blockMesh. I used polyLine to create the geometry with varying radius.
sandy
Rep Power: 4 ![]() |
Thread Tools | |
Display Modes | |
[ANSYS Meshing] Creating a good mesh on difficult geometry | Jipkrens1 | ANSYS Meshing & Geometry | 11 | January 30, 2018 07:29 |
[ANSYS Meshing] Having dificulty creating geometry of a 2 non-miscible fluid tutorial | flodrows | ANSYS Meshing & Geometry | 2 | November 2, 2015 05:33 |
[DesignModeler] Creating a body part from an imported geometry | tec | ANSYS Meshing & Geometry | 0 | July 27, 2015 07:09 |
Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
Frustrated creating your own geometry? | Brian Coon | Main CFD Forum | 0 | November 23, 1999 07:36 |
