[blockMesh] errors in topology while running 'blockMesh' |
February 14, 2018, 12:50 |
shima
Rep Power: 8 |
Hello everyone,
I am trying to make a floating break water with triangle sides. I tried to make the geometry with blockMesh because I did not have boxes to make with topoSetDict. However while I am running the blockMesh, I receive an error: Creating curved edges Creating topology blocks --> FOAM Warning : From function bool Foam::blockMesh::blockLabelsOK(...) in file blockMesh/blockMeshCheck.C at line 179 out-of-range point label 108 (max = 103) in block 2 Creating topology patches Reading patches section --> FOAM FATAL ERROR: Cannot create mesh due to errors in topology, exiting ! From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 468. FOAM exiting blockMeshDict.zip I did check the points and blocks, but the error still exist!!!! please find my enclosed blockMeshDict and help me through solving the error.. Thanks. |
February 14, 2018, 21:22 |
Rep Power: 15 |
The problem comes because you have commented out some of the vertices, yet continued to keep their index: Code:
(7 -0.16 0.3)//62 (7.2 -0.16 0.3)//63 (7.2 -0.2 0.3)//64 (7.206 -0.2 0.3)//65 (7.206 -0.16 0.3)//66 (7.394 -0.16 0.3)//67 (7.394 -0.2 0.3)//68 (7.4 -0.2 0.3)//69 (7.4 -0.16 0.3)//70 (7.6 -0.16 0.3)//71 (7.4 0 0.3)//72 (7.4 0.04 0.3)//73 (7.2 0.04 0.3)//74 (7.2 0 0.3)//75 /* (7 0 0)//76 (6 0 0)//77 (-5 0 0)//78 */ (-5 -0.16 0)//79 (6 -0.16 0)//80 /* (7.6 0 0)//81 (15 0 0)//82 (25 0 0)//83 */ Essentially what you have marked as "//79" will actually be counted as "//76" because there is a commented out section in between. The simplest way to solve this is to remove the comments and have all your 120 vertices (0-120) present in the vertices definition, but use only a few of them to create your blocks. Alternatively, if you want to keep the commenting, then you would have to redo the index of the vertices, especially the ones after a comment block. Cheers, Antimony |
February 15, 2018, 05:56 |
#3 | |
shima
Rep Power: 8 |
Thank you so much for your hint. My problem solved based on the way that you suggested and right now I can see my shape in paraview. Best regards, Shima. |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
