[blockMesh] blockMesh cylinder with two inlets |
March 7, 2018, 04:53 |
anonymous
Rep Power: 8 |
Hello everyone. I am new to openFOAM. I managed to blockmesh a cylinder using the m4 file in this link.
https://www.ehsanmadadi.com/cylinder-mesh/ Then I want to create a second inlet on the wall as shown in the image attached. Can anyone please tell me how to write this in blockmesh. pipe.JPG |
March 7, 2018, 05:10 |
Uwe Pilz
Rep Power: 15 |
Very probably there exist some ways to handle this.
If I had to manage this case, I would generate a regular cylinder with a slightly different formulation for the wall speed (which is zero in most places at the wall). It is possible to use for a surface a nonuniform velocity in the form Code:
type fixedValue; value nonuniform List<vector> {elements} ( (ux0 uy0 uz0) (ux1 uy1 uz1) : )
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 7, 2018, 05:23 |
anonymous
Rep Power: 8 |
Thank you very much for the quick reply. Really appreciate it. I will definitely try this.
March 7, 2018, 21:44 |
Rep Power: 15 |
If you are using OF 5, then you could try their new "project" feature: https://cfd.direct/openfoam/user-guide/blockmesh/ (Look for section 5.3.3) Cheers, Antimony |
March 9, 2018, 12:02 |
anonymous
Rep Power: 8 |
Thank you very much for the info. Really appreciate it. I will try this.
Problem with verification of transverse freely moving cylinder | aakie | OpenFOAM Running, Solving & CFD | 4 | August 3, 2019 09:01 |
[blockMesh] BlockMesh with cylinder and halfsphere | ich558 | OpenFOAM Meshing & Mesh Conversion | 0 | April 11, 2019 05:17 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
