January 4, 2019, 06:44 |
OpenFOAM blockMeshDict error
Ahmad Rifqi
I have tried several times, including the past questions that are solved. I could decrease the error significantly, but I still can not solve this particular problem. Here is the code,
/*--------------------------------*- C++ -*----------------------------------*\ | Geometry : Cavity CFD | | Author : Ahmad Rifqi | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (0 2 0) //1 (4 2 0) //2 (5 2 0) //3 (5 1 0) //4 (4 1 0) //5 (4 0 0) //6 (0 0 1) //7 (0 2 1) //8 (4 2 1) //9 (5 2 1) //10 (5 1 1) //11 (4 1 1) //12 (4 0 1) //13 ); blocks ( hex (5 12 11 4 2 9 10 3) (200 100 1) simpleGrading (1 1 1) hex (7 13 6 0 8 9 2 1) (200 100 1) simpleGrading (1 1 1) ); edges ( ); boundary ( Inlet { type patch; faces ( (10 11 4 3) ); } Outlet { type patch; faces ( (0 1 8 7) ); } Wall { type patch; physicalType wall; faces ( (5 12 11 4) (2 9 10 3) (1 8 9 2) (9 12 11 10) (8 7 13 9) (1 0 6 2) (2 5 4 3) (0 7 13 6) (13 6 5 12) //why is this line error? ); } ); mergePatchPairs ( ); // ************************************************************************* // I do not understand why does the 76 th line gives me an error. Anybody knows why? Last edited by ahmadrifqi; January 4, 2019 at 06:45. Reason: I forget to write the code differently. |
January 6, 2019, 23:50 |
Rep Power: 15 |
The error is because there is no hex block where the vertices 13, 6, 5 and 12 are ALL present. In order to define a set of vertices as a face, they must all be present in the same block. Hope this helps. Cheers, Antimony |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
