[blockMesh] How to construct a block with four vertices |
November 5, 2008, 20:44 |
Jia Rui
Generally a block needs 8 vertices, but now I have to tackle the intersection of two cylinders with equal diameters. The intersection part can be seen as four polyhedrons, each of which has four vertices and four surface.
I found block with six vertices constructed from page 136 of User Guide for OpenFOAM 1.5. But does anyone know if it is possible to construct block with four vertices? Thanks in advance! |
[ICEM] Scripting: Naming of block vertices | ayoung94 | ANSYS Meshing & Geometry | 1 | April 20, 2018 04:33 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
[blockMesh] block with 6 vertices | Hale | OpenFOAM Meshing & Mesh Conversion | 1 | October 5, 2013 08:00 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
