BlockMesh face merging
Is there a blockMesh file in the tutorials where face merging is used? I want to look at the syntax.
Thank you! |
I think there's merging in the
I think there's merging in the example case:
$FOAM_TUTORIALS/simpleFoam/pitzDaily3Blocks The documentation about face merging is at: http://www.opencfd.co.uk/openfoam/do...32-1680006.3.2 |
In my case, `simpleFoam . pitz
In my case, `simpleFoam . pitzDaily3Blocks` shows "--> FOAM FATAL IO ERROR : keyword interface is undefined ....".
So I changed the type of interface from patch to wall and added some lines like interface { type fixedValue; value uniform (0 0 0); } to 0/{R,U,epsilon,k,nuTilda,p}. After these changes I can excute it. I think that after merging the patch "interface" has no sence but simpleFoam may not think so,,, |
I want to attach (merge) a cub
I want to attach (merge) a cuboid to the curved surface of a cylinder with blockMesh. The blockMesh tool generates a grid which looks good. But at the merged cell layers it somehow produces pyramid-cells, which are unwanted.
What can I do to merge the cuboid to the cylinder without the pyramid-cells? May somebody with blockMesh experience can look at it?! I attache the blockMeshDict file http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif blockMeshDict |
Hi Duderino,
I run checkMes
Hi Duderino,
I run checkMesh on your geometry and get hexahedra: 2516 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 9 Number of regions: 1 (OK). So it seems to have correctly merged the cells and introduced 9 general polyhedra (i.e. anything not of the above) on the interface. You might see them as pyramids since vtk/paraview cannot handle polyhedra and we decompose them before passing them to vtk) You can pick these up using the cellSet utility (in mesh/manipulation). See the cellSetDict dictionary on how to use it ('shapeToCell') Mattijs |
Hi Mattijs,
Thank you for y
Hi Mattijs,
Thank you for your help. If I merge two patches (surfaces) at the exakt same location of the exakt same size, I will get two "internal" patches(with nFaces 0). Allthough this "internal" patch has zero(?) Faces, I am still asked for a boundary condition. Does it matter which boudary I choose? Thank you! |
a) leave them there and give t
a) leave them there and give them a 'simple' boundary condition (e.g. fixedValue)
b) remove them. You can edit the polyMesh/boundary file and remove the patches with zero faces (and adapt the number of patches at the top of the file). (Note that removing patches is only allowed for zero-sized patches) |
Hi Mattijs,
I've applied yo
Hi Mattijs,
I've applied your suggestion b) to simpleFoam/pitzDaily3Blocks and it goes fine. Thanks. |
I am trying to merge two patch
I am trying to merge two patches with a shared edge. Could any one tell me how to declare both patches as the masters. Thanks!
Jim |
hi everyone. i was trying to c
hi everyone. i was trying to create a mesh around a solid cylinder. can anyone suggest me which will be the best way? as im new to openfoam, i started with quarter part of the whole mesh to be generated containg the quarter of the cylinder. i did it in blockmesh...while executing it, i was finding the following errors. can anyone suggest me what might be the bug in here?
/*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh /home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam cavi tyGrade Date : Jun 24 2008 Time : 09:42:12 Host : localhost PID : 22816 Root : /home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam Case : cavityGrade Nprocs : 1 Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 12 Number of defined boundary faces : 12 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Creating merge patch pairs Adding point and face zones Creating attachPolyTopoChanger #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/nikhil/OpenFOAM/OpenFOAM-1 .4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/li b/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::triangle<foam::vector<double>, Foam::Vector<double> const&>::ray(Foam: :Vector<double> const&, Foam::Vector<double> const&, Foam::intersection::algorit hm, Foam::intersection::direction) const in "/home/nikhil/OpenFOAM/OpenFOAM-1.4. 1/lib/linuxGccDPOpt/libmeshTools.so" #4 Foam::face::ray(Foam::Vector<double> const&, Foam::Vector<double> const&, Fo am::Field<foam::vector<double> > const&, Foam::intersection::algorithm, Foam::in tersection::direction) const in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxG ccDPOpt/libOpenFOAM.so" #5 Foam::List<foam::objecthit> Foam::PrimitivePatch<foam::face,> > const&>::projectPoints<foam::primitivepatch<foam> > const&> >(Foam::Primitive Patch<foam::face,> > const&> const&, Foam::Field<foam::vector<double> > const&, Foam::intersection::algorithm, Foam: :intersection::direction) const in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/lin uxGccDPOpt/libdynamicMesh.so" #6 Foam::slidingInterface::projectPoints() const in "/home/nikhil/OpenFOAM/Open FOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #7 Foam::slidingInterface::changeTopology() const in "/home/nikhil/OpenFOAM/Ope nFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #8 Foam::polyTopoChanger::changeTopology() const in "/home/nikhil/OpenFOAM/Open FOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #9 Foam::polyTopoChanger::changeMesh(bool, bool) in "/home/nikhil/OpenFOAM/Open FOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #10 Foam::attachPolyTopoChanger::attach(bool) in "/home/nikhil/OpenFOAM/OpenFOA M-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #11 main in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOp t/blockMesh" #12 __libc_start_main in "/lib/i686/libc.so.6" #13 Foam::regIOobject::readIfModified() in "/home/nikhil/OpenFOAM/OpenFOAM-1.4. 1/applications/bin/linuxGccDPOpt/blockMesh" regards, nikhil. |
1 Attachment(s)
>blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh Date : Feb 23 2010 Time : 08:48:53 Host : seshasai-srinivasans-macbook-pro.local PID : 2538 Case : /Volumes/OpenFOAM/stsriniv-1.5/run/tutorials/interFoam/poreDrop/mergeTest nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 576 Found 5 undefined faces in mesh; adding to default patch. Check block mesh topology Basic statistics Number of internal faces : 8 Number of boundary faces : 20 Number of defined boundary faces : 20 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty mergePatchPairs not currently supported. From function blockMesh in file genBlockMesh.C at line 198. FOAM exiting |
I could run your code, maybe it's just a different version of OF, 1.6 instead of 1.5 (where mergePatchPairs is not currently supported.)
Marco |
Hey Mattijs, I am having a similar problem while merging faces. I could not undertand this part of ur message. "You can pick these up using the cellSet utility (in mesh/manipulation). See the cellSetDict dictionary on how to use it ('shapeToCell')" can u pl help Thanks Ramnik |
