[blockMesh] blockMesh being killed automatically |
September 16, 2015, 13:52 |
Jess
Rep Power: 10 |
Hello. I have been trying to create a simulation of semi-submersible platform but as it has 62 blocks, I decided to start trying to simulate just the bottom part first, which has 24 blocks. The problem is that when I use the command blockMesh, my mesh starts being generated and right after the 24 blocks get created it shoes a message saying "killed" and it stops. I thought it was a problem with my computer, so I tried to run it in other two computers, the same problem occurred. Anyone knows what the problem can be?
Thanks. |
August 11, 2016, 15:24 |
Thomas Oliveira
Rep Power: 12 |
Insufficient memory may be the reason why blockMesh is being killed, as explained on this post.
I needed to generate a mesh for a rectangular cuboidal domain divided into smaller identical rectangular cuboids. For this specific type of mesh, I have written a C++ program that creates the same files that would be created by blockMesh. It is available here in case it can be useful to other people. Using this code, I was able to generate a 500x500x500 mesh that I couldn't generate using blockMesh on my computer with 64 GB RAM. It takes 70% more time than the OpenFOAM's blockMesh, but requires 40% less memory. [EDIT: a new version is available on the same link. Now it takes 24% more time than the OpenFOAM's blockMesh, but requires at most 80 MB, independently of the mesh size.] Best wishes, Thomas Last edited by t.oliveira; August 12, 2016 at 13:17. |
April 5, 2018, 21:06 |
KAWA
Rep Power: 8 |
Dear Thomas, How I can get the file, it seems the link does not work for me, Thanks in advance
November 23, 2023, 08:53 |
How to create polymesh file from bolckMeshdict outside openFoam?
Debabrata Adhikari
Is there any other way to create polyMesh file outside openFOAM from the bolckMeshDict information? The bolckMeshDict has multiple blocks, not a single regular cubic domain. Does anyone have any comment on this? I want to make it outside openFOAM because my machine can not handle the large meshes. Thank you, Debabrata |
November 23, 2023, 09:27 |
Yann
Rep Power: 26 |
There are several utilities in OpenFOAM to import mesh from other software (gmsh, Salome, ANSYS, ...) http://www.wolfdynamics.com/wiki/mesh_conversion.pdf But if your problem is your machine not being able handle such a large mesh, I doubt this will solve your problem. You will still end up with a mesh too large for your machine to handle, unless you change your meshing strategy. Regards, Yann |
blockmesh, blockmesh polymesh manual, ihfoam, openfoam |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
