[blockMesh] not able to arrange the arc 12 13 |
March 26, 2012, 09:09 |
Angelo2000
hello, I have a problem in the grid below, I am not able to arrange the arc 12 13, q may have something wrong before I am not able to check more.
thank you /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) // 0 (0 0 -1) // 1 (0 1 -1) // 2 (0 1 0) // 3 (10 0 0) // 4 (10 0 -1) // 5 (10 1 -1) // 6 (10 1 0) // 7 (0 -0.5 0.5) // 8 (0 1.5 0.5) // 9 (10 1.5 0.5) // 10 (10 -0.5 0.5) // 11 (0 -0.5 -1.5) // 12 (0 1.5 -1.5) // 13 (10 1.5 -1.5) // 14 (10 -0.5 -1.5) // 15 (0 -1 1) // 16 (0 2 1) // 17 (10 2 1) //18 (10 -1 1) //19 (0 -1 -2) //20 (0 2 -2) //21 (10 2 -2) //22 (10 -1 -2) //23 ); blocks ( hex (0 1 2 3 4 5 6 7) (5 5 5) simpleGrading (1 1 1) hex (0 3 9 8 4 7 10 11) (5 5 5) simpleGrading (1 1 1) hex (1 12 13 2 5 15 14 6) (5 5 5) simpleGrading (1 1 1) hex (2 13 9 3 6 14 10 7) (5 5 5) simpleGrading (1 1 1) hex (1 0 8 12 5 4 11 15) (5 5 5) simpleGrading (1 1 1) ); edges ( arc 0 1 (0 1.414214 -1) arc 1 2 (0 1 1.414214) arc 2 3 (0 -1.414214 1) arc 3 0 (0 1 -1.414214) arc 4 5 (10 1.414214 -1) arc 5 6 (10 1 1.414214) arc 6 7 (10 -1.414214 1) arc 7 4 (10 -1 -1.414214) arc 8 12 (0 -0.707107 -1) arc 12 13 (0 1 0.707107) arc 13 9 (0 0.707107 1) arc 9 8 (0 1 0.707107) arc 11 15 (10 -0.707107 -1) arc 15 14 (10 1 0.707107) arc 14 10 (10 0.707107 1) arc 10 11 (10 1 0.707107) ); boundary ( inlet { type patch; faces ( ); } outlet { type patch; faces ( ); } fixedWalls { type wall; faces ( ); } frontAndBack { type empty; faces ( ); } ); mergePatchPairs ( ); // ************************************************** *********************** // Last edited by Angelo2000; March 26, 2012 at 09:25. |
March 26, 2012, 10:43 |
Hi Angelo,
Based on you figure, I would say you have inconsitent vertices and/or blocks. Please double-check them. Jose |
March 26, 2012, 12:38 |
Angelo2000
March 27, 2012, 19:14 |
Disabled
arc 3 0 (0 -1 -1.414214)
arc 12 13 (0 1 x) arc 15 14 (10 1 x) where x about equal to -1.6 (from testing, no time to check the exact geometrical value, you should do that) |
April 2, 2012, 09:40 |
Angelo2000
http://imageshack.us/photo/my-images/39/cilindro2.png
Hello we managed to get the mesh, the more checkMesh says that the mesh is not orthogonal, can someone help with this part. The mesh is below. Thank you. Angelo /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) // 0 (0 0 -1) // 1 (0 1 -1) // 2 (0 1 0) // 3 (20 0 0) // 4 (20 0 -1) // 5 (20 1 -1) // 6 (20 1 0) // 7 (0 -0.5 0.5) // 8 (0 1.5 0.5) // 9 (20 1.5 0.5) // 10 (20 -0.5 0.5) // 11 (0 -0.5 -1.5) // 12 (0 1.5 -1.5) // 13 (20 1.5 -1.5) // 14 (20 -0.5 -1.5) // 15 ); blocks ( hex (0 1 2 3 4 5 6 7) (5 5 5) simpleGrading (1 1 1) hex (0 3 9 8 4 7 10 11) (5 5 5) simpleGrading (1 1 1) hex (1 12 13 2 5 15 14 6) (5 5 5) simpleGrading (1 1 1) hex (2 13 9 3 6 14 10 7) (5 5 5) simpleGrading (1 1 1) hex (1 0 8 12 5 4 11 15) (5 5 5) simpleGrading (1 1 1) ); edges ( arc 0 1 (0 3 -1) arc 1 2 (0 1 3) arc 2 3 (0 -3 1) arc 3 0 (0 -1 -3) arc 4 5 (20 3 -1) arc 5 6 (20 1 3) arc 6 7 (20 -3 1) arc 7 4 (20 -1 -3) arc 8 12 (0 -0.8 -1) arc 13 12 (0 -1 -0.8) arc 13 9 (0 0.8 1) arc 9 8 (0 -1 -0.8) arc 11 15 (20 -0.8 -1) arc 14 15 (20 -1 -0.8) arc 14 10 (20 0.8 1) arc 10 11 (20 -1 -0.8) ); boundary ( inlet { type patch; faces ( (0 1 2 3) (0 3 9 8) (1 12 13 2) (2 13 9 3) (1 0 8 12) ); } outlet { type patch; faces ( (4 5 6 7) (4 7 10 11) (5 15 14 6) (6 14 10 7) (5 4 11 15) ); } fixedWalls { type wall; faces ( (8 9 10 11) (12 13 14 15) ); } frontAndBack { type empty; faces ( (9 13 14 10) (8 12 15 11) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
April 3, 2012, 08:22 |
cfdkid
Friend,
Try using salomne tool to generate geometry save it in STL.binary and import that using discritizer tool and set up your case using it. Both Salomne and Discritizer are free tools ( OS linux). Sorry, but could not help your issue directly. Regards CFDkid |
April 3, 2012, 08:33 |
#7 | |
Angelo2000
Hello and thanks for helping, I have a friend who is already using more discritizer my teacher wants you to do in blockMesh. how do you import the STL file OpenFoam? you can do a step by step? Angelo |
April 3, 2012, 08:40 |
I think this discussion goes against any forum rules… even if anybody was willing to help you, nobody can probably understand what's going on here…
Did you manage to get your mesh? Probably yes, but you're saying checkmesh is reporting some errors (or maybe just warning), so, why don't you post your errors instead of your blockmesh? |
April 4, 2012, 00:22 |
cfdkid
hello craft,
What you said is right, one needs to post error or warning message of OpenFOAM. Also this is high time to bring to notice these facts given at bottom of this thread. http://www.cfd-online.com/Forums/ope...-get-help.html Another matter i would like to get informed about is that, should we discuss use of Salome, Discritizer ? As these tools help to abstract some of the complications and once problem is set we are free to work in OpenFOAM. regards, CFDkid |
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from | syntex | OpenFOAM Meshing & Mesh Conversion | 19 | December 10, 2018 07:21 |
[Other] Change the mesh in mixerVesselAMI2D tutorial | hoemmaria | OpenFOAM Meshing & Mesh Conversion | 2 | October 6, 2017 07:43 |
[blockMesh] Another cylinder question | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 5 | January 6, 2015 05:09 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 08:11 |
[blockMesh] apparently the mesh doesn't want to be created in one direction | Maxime Thomas | OpenFOAM Meshing & Mesh Conversion | 1 | August 18, 2012 06:05 |
