October 6, 2013, 21:08 |
ideasUnvToFoam error
Rep Power: 12 |
Hello
I am new to CFD and openFoam in general and having problems converting my mesh. It is a fairly simple model of 2D flow around a cylinder, I have two cases one laminar and one turbulent however I get the same error with both when I run the command ideasUnvToFoam and get the following : /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.1-57f3c3617a2d Exec : ideasUnvToFoam Mesh_2.unv Date : Oct 06 2013 Time : 19:47:30 Host : "Matt-PC" PID : 2997 Case : /home/matt/Documents/Mech444/cylinder_turbulent nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 11764 points. Processing tag:2412 Starting reading cells at line 23551. First occurrence of element type 11 for cell 1 at line 23552 First occurrence of element type 41 for cell 439 at line 24866 First occurrence of element type 111 for cell 16125 at line 56238 Read 45131 cells and 15686 boundary faces. Processing tag:2467 Starting reading patches at line 146502. For group 1 named inlet trying to read 278 patch face indices. For group 2 named outlet trying to read 278 patch face indices. For group 3 named top_bottom trying to read 1540 patch face indices. For group 4 named front_back trying to read 13354 patch face indices. For group 5 named top_bottom trying to read 1540 patch face indices. For group 6 named face trying to read 236 patch face indices. Sorting boundary faces according to group (patch) 0: inlet is patch 1: outlet is patch 2: top_bottom is patch 3: front_back is patch 4: top_bottom is faceZone 5: face is patch Constructing mesh with non-default patches of size: inlet 278 outlet 278 top_bottom 1540 front_back 13354 face 236 Adding cell and face zones Face Zone top_bottom 1540 ideasUnvToFoam: ideasUnvToFoam.C:1273: int main(int, char**): Assertion `noveau > -1' failed. Aborted (core dumped) I have searched and found a similar problem being fixed with a patch but this didn't seem to work for me. Could anyone advise please? Thanks Matt |
October 7, 2013, 20:32 |
Rep Power: 12 |
Silly error, I put in top_bottom twice...now fixed
March 11, 2014, 12:19 |
Amin S
Rep Power: 12 |
Hi Matt. I have the same problem.
my geometry and mesh groups were created in salome-meca and seem to be ok. no duplicate faces or extra edges. when I use ideasUnvToFoam,terminal issues warning: Sorting boundary faces according to group (patch) 0: inlet is patch 1: outlet is patch 2: cylinder is faceZone 3: top is patch 4: bottom is patch 5: front is patch 6: back is faceZone Constructing mesh with non-default patches of size: inlet 450 outlet 450 top 450 bottom 450 front 5973 --> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 626 Found 6423 undefined faces in mesh; adding to default patch. Adding cell and face zones Face Zone cylinder 2025 ideasUnvToFoam: ideasUnvToFoam.C:1271: int main(int, char**): Assertion `noveau > -1' failed. Aborted (core dumped) how did you manage to fix it? what do you mean by "put top_bottom" twice?? |
October 5, 2015, 11:05 |
Arpit
Rep Power: 11 |
Did anybody find a way around it ?
I am only 4 different face groups and I am getting the same error .. |
ideasunvtofoam, mesh 2d, meshing |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
