[Gmsh] Flow over an aifoil mesh strategy using gmsh |
May 25, 2015, 16:47 |
CFD
Rep Power: 16 |
Hello All,
I have working on an airfoil case using gmsh to obtain the proper drag and lift. I have used this following strategy, mesh strategy.jpg However, I have not obtained a proper drag according to the literature. Can some body guide me in a proper mesh strategy. Thank you all, |
May 26, 2015, 06:06 |
#2 | |
Rep Power: 12 |
your approach doesn't look bad to me. What exactly is your question regarding the mesh strategy? I hardly know gmsh. So can you please explain to me how you created your domain? Did you first import your geometry as an *.stl file and thereafter created the boundaries in gmsh? Best regards, Kate |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ANSYS Meshing] Meshing Strategy for inside geometry | powpow | ANSYS Meshing & Geometry | 6 | January 16, 2013 04:32 |
[ICEM] Mesh strategy large tank | DoubleG | ANSYS Meshing & Geometry | 2 | January 10, 2013 10:15 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
