[Gmsh] Making a cylindrical hole in a cubic domain (wellbore) in GMsh |
July 29, 2015, 18:36 |
Igor Shovkun
Hello everyone!
I am trying to create a 3D mesh to simulate geomechanics in a cubic domain with a deviated wellbore. I have build all the geometry, surface (2D) mesh generation works fine. When I try to create a 3D mesh for a volume, GMsh fills the hollow space as well. Could anybody help me with that? There follows my code: ft = 0.3048; xSize = 20*ft; ySize = 20*ft; zSize = 20*ft; esize = 1*ft; deg = 2*Pi/360; alpha = 85*deg; // angle between hor plane and well beta = 0*deg; // angle between x and well r = 2*ft; // well radius // parameters of the horizontal cross-section e = Cos(alpha); a = r/Sin(alpha); b = a*Sqrt(1-e^2); // creating ellipse Point(1) = {a*Cos(beta),a*Sin(beta),0,esize}; // first point of the arc Point(2) = {0,0,0,esize}; // center Point(3) = {a/2*Cos(beta),a/2*Sin(beta),0,esize}; // point in major axis Point(4) = {b*Sin(beta),b*Cos(beta),0,esize}; // end point of the arc Point(5) = {-a*Cos(beta),-a*Sin(beta),0,esize}; // first point of the arc Point(6) = {-b*Sin(beta),-b*Cos(beta),0,esize}; // end point of the arc Ellipse(1) = {1,2,3,4}; Ellipse(2) = {4,2,3,5}; Ellipse(3) = {5,2,3,6}; Ellipse(4) = {6,2,3,1}; // Line Loop(5) = {1,2,3,4}; Line Loop(5) = {-4,-3,-2,-1}; out[] = Extrude{ zSize*Cos(alpha)*Cos(beta), zSize*Cos(alpha)*Sin(beta), zSize} { // Surface{6}; // Loop{5}; Line{-4,-3,-2,-1}; }; // // Points // Bottom Point(31) = {xSize/2,ySize/2,0,esize}; Point(32) = {-xSize/2,ySize/2,0,esize}; Point(33) = {-xSize/2,-ySize/2,0,esize}; Point(34) = {xSize/2,-ySize/2,0,esize}; // Top Point(35) = {xSize/2,ySize/2,zSize,esize}; Point(36) = {-xSize/2,ySize/2,zSize,esize}; Point(37) = {-xSize/2,-ySize/2,zSize,esize}; Point(38) = {xSize/2,-ySize/2,zSize,esize}; // Lines // Bottom Line(31) = {31,32}; Line(32) = {32,33}; Line(33) = {33,34}; Line(34) = {34,31}; Line Loop(35) = {31,32,33,34}; surf2 = news; Plane Surface(surf2) = {35,5}; // bottom surf // // Top Line(36) = {35,36}; Line(37) = {36,37}; Line(38) = {37,38}; Line(39) = {38,35}; Line Loop(40) = {36,37,38,39}; Line Loop(41) = {out[0],out[5],out[10],out[15]}; // upper ellipse // Plane Surface(666) = {41}; surf3 = news; Plane Surface(surf3) = {40,41}; //top surf // Front Line(42) = {34,38}; Line(43) = {38,37}; Line(44) = {37,33}; Line(45) = {33,34}; Line Loop(46) = {42,43,44,45}; surf4 = news; Plane Surface(surf4) = {46}; // Left Line(47) = {33,37}; Line(48) = {37,36}; Line(49) = {36,32}; Line(50) = {32,33}; Line Loop(51) = {47,48,49,50}; surf5 = news; Plane Surface(surf5) = {51}; // Back Line(52) = {32,36}; Line(53) = {36,35}; Line(54) = {35,31}; Line(55) = {31,32}; Line Loop(56) = {52,53,54,55}; surf6 = news; Plane Surface(surf6) = {56}; // Right Line(57) = {31,35}; Line(58) = {35,38}; Line(59) = {38,34}; Line(60) = {34,31}; Line Loop(61) = {57,58,59,60}; surf7 = news; Plane Surface(surf7) = {61}; surf8 = news; // Surface Loop(surf8) = {surf2,surf5,surf4,surf3,surf6,surf7,-9,-13,-17,-21} ; Surface Loop(surf8) = {surf2,-9,-13,-17,-21,surf3,surf5,surf4,surf7,surf6} ; Volume(1) = {surf8} ; // |
July 30, 2015, 10:44 |
Solution
Igor Shovkun
In case anyone needs the solution, I got this!
Just add Coherence; As the last line, and It will work as a charm. |
February 25, 2020, 12:02 |
cylinder only partial
Thomas Flint
Rep Power: 10 |
Thanks so much for your post. I'm very new to gmsh but was wondering if you could help me figure out how to remove a cylindrical region from the domain that doesnt go all the way through? I tried halving the extrude length but the mesh is missed off from the bottom half of the cylinder if I do this. Thanks in advance |
cylindrical hole, wellbore |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Making Geometry in Gmsh | rahulsng | OpenFOAM | 1 | January 14, 2012 06:05 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
