[Gmsh] Conversion GMSH geo-file to msh-file to openFoam case does not work |
December 29, 2017, 17:50 |
Georg
Rep Power: 8 |
i am wondering if i am the only One Stepping from One problem to the Next. i finally got myself to run the openfoam Tutorial cavity problem and to got used to paraview. i thought i could go ahead and i managed to create a structered Mesh im gmesh...just a Channel to get the hagen-poiseulle Flow where i can validate the result with the Analytical Solution. i followed the Tutorials, where i Converted the geo-file Into msh-file with gmsh file.geo -3 -o file.msh. and then with gmshtofoam file.msh -case case_dir. What can go wrong here? just 2 steps...and it fails during gmshtofoam because no vertices etc. can be found. i Need some advice here. Thanks in advance George |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
