[Gmsh] gmsh - mesh set by Field Threshold does not increase in size as expected |
November 6, 2018, 05:31 |
Adam
Rep Power: 7 |
I would like to have a higher mesh density in/around some cylinders that are dispersed within a matrix. When I only have one cylinder present, the results are as expected; the element sizes increase away from the cylinder. However, when multiple cylinders are present, this is not the case.
R = 10; LC = 50; Field[1] = Distance; Field[1].NNodesByEdge =40; Field[1].EdgesList = {CircleIndex[]}; Field[2] = Threshold; Field[2].IField = 1; Field[2].LcMin = R/5; Field[2].LcMax = LC; Field[2].DistMin = 2*R; Field[2].DistMax = 5*R; Background Field = 2; |
November 11, 2018, 23:40 |
nevermind
Adam
Rep Power: 7 |
I figured it out.
Options > Mesh > Advanced Uncheck "Extend element sizes from boundary" |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
