[Gmsh] Boundary face
Old   May 17, 2006, 15:11
Default Boundary face
Pei-Ying Hsieh
hsieh is on a distinguished road
Has anyone tried to export the mesh together with the bounday face information directly from gmsh?
I just started playing with gmsh. Can someone post the steps how this can be done?
I have asked the same question on the gmsh mailing list, but, still no reponse yet.
Thanks!
Pei
hsieh is offline   Reply With Quote
Old   August 30, 2009, 17:57
Steve Hansel
hansel is on a distinguished road
You create your geometry using lines, planes and volumes. Then you create
Physical Surfaces which are named.
example: Physical Surface ("top") = {3,4};
where 3 and 4 are surface numbers.
If you create physical surfaces, then make sure you also create a physical volume or nothing will end up in OpenFOAM.
[Yes, I realize this question is 3 years old, but someone should really answer some of these for new people seaching these forums.]
hansel is offline   Reply With Quote
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Simulating fire in a tunnel luca1992 OpenFOAM 14 August 16, 2017 13:50
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
