[Netgen] Meshing error
Old   November 16, 2006, 03:15
Default Meshing error
ares_tum
Hallo,everyone
I got a very complicated but perfect model.
But i failed to mesh it, since it showed in the command window:
Load stl geometry file /home/cluster/t5131br/Documents/netgen/Zigo_zoom.stl
ERROR: Give up because of too many trials. Meshing aborted!
Meshing done, time = 5401.32 sec
Could anyone tell me what's the problem?
Thanks
Old   November 16, 2006, 04:45
Default - run your surface though surf
Mattijs Janssens
- run your surface though surfaceCheck or any other tool that checks the surface. See if it is a single connected, non-intersecting surface.
- specify smaller tets. Netgen sometimes gives up if the surface is too complicated for the tet size you specified.
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
