[snappyHexMesh] problemes modelling surfaces with snappyhexmesh
Old   June 23, 2010, 11:30
Default problemes modelling surfaces with snappyhexmesh
Silvia Di Francesco
gija79 is on a distinguished road
Hi everybody,
i'm trying to build a mesh with the snappyhexmesh utility.
I want to model the flow over a submerged island, but snappyhex seems to fail in snapping to island surface.
I want to use the InterFoam solver.
Maybe I did'nt prepare the dict file well, but the resulting mesh is very poor.
I prepared the background mesh with blockmesh.
This is my blockmesh file:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)//0
(300 0 0)//1
(300 85 0)
(-170 85 0)//3
(-170 0 1)
(300 0 1)//5
(300 85 1)
(-170 85 1)//7
blocks
hex (0 1 2 3 4 5 6 7) (300 85 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 7 3)
patch outlet
(1 5 6 2)
wall bottom
(0 4 5 1)
patch atmosphere
(3 7 6 2)
mergePatchPairs
This is the snappyhex dict file:
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
coral.stl
type triSurfaceMesh;
name coral;
refinementBox
type searchableBox;
min (60 20 -0.1);
max (98 27 1.1);
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// While refining maximum number of cells per processor. This is basically
// the number of cells that fit on a processor. If you choose this too small
// it will do just more refinement iterations to obtain a similar mesh.
maxLocalCells 1000000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 2000000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 10;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
// file "someLine.eMesh";
// level 2;
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
coral
// Surface-wise min and max refinement level
level (5 6);
// Resolve sharp angles
resolveFeatureAngle 30;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
coral
mode distance;
levels ((0.01 6)(0.1 5) (0.5 4) (1 2));
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (75 35 0.5);
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 5;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 3.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
coral_bottom
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.0;
//- Wanted thickness of final added cell layer. If multiple layers
// is the
// thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
finalLayerThickness 0.3;
//- Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.1;
//- If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
nGrow 1;
// Advanced settings
//- When not to extrude surface. 0 is flat surface, 90 is when two faces
// make straight angle.
featureAngle 30;
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
minMedianAxisAngle 130;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
//- Max skewness allowed. Set to <0 to disable.
maxBoundarySkewness 20;
maxInternalSkewness 4;
//- Max concaveness allowed. Is angle (in degrees) below which concavity
// is allowed. 0 is straight face, <0 would be convex face.
// Set to 180 to disable.
maxConcave 80;
//- Minimum projected area v.s. actual area. Set to -1 to disable.
minFlatness 0.5;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
// Set to very negative number (e.g. -1E30) to disable.
minVol 1e-13;
//- Minimum face area. Set to <0 to disable.
minArea -1;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
//- and face centre triangles normal
minTwist 0.02;
//- minimum normalised cell determinant
//- 1 = hex, <= 0 = folded or flattened illegal cell
minDeterminant 0.001;
//- minFaceWeight (0 -> 0.5)
minFaceWeight 0.02;
//- minVolRatio (0 -> 1)
minVolRatio 0.01;
//must be >0 for Fluent compatibility
minTriangleTwist -1;
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
and finally in attachment the stl file (in binary and ascii).
Can anybody help me?
I also tried to use gmsh to build the mesh but I'm not able to do a 2D case .
I make a 3D case but the mesh is too irregular for OpenFoam.
Thank you in advance
Silvia
gija79 is offline   Reply With Quote
Old   June 24, 2010, 01:36
Alan Russell
AlanR is on a distinguished road
Sylvia,
I see a few problems with your setup. In the blockMeshDict you have not defined the sides of your domain. These either need to be empty for 2D or defined patches for 3D. The motorbike tutorial blockMeshDict is a good example of a 3D blockMesh, or use the cavity tutorial for 2D.
For your snappyHexMesh setup, I would suggest commenting out the refinementBox, in refinementSurfaces setting the level to (2 2) will make things faster. You can refine it later if needed, after you get things working. Also comment out everything in refinementRegions and set the expansion ratio to 2 in addLayerControls (again, you can adjust this later).
If you have a good 3D surface .stl file, I would setup a 3D blockMesh - If you want to run a 3D model (flow over a submerged island sounds like a 3D model to me). Finally, I had a lot of mesh problems when I started from the motorBike tutorial. I suggest using the system directory files (fvSolution and fvSchemes) from the moveDynamicMesh tutorial. The solvers for cellDisplacement and cellMotion made things work better for me. I suggest running blockMesh separately, then run paraFoam to look at the mesh. If it looks OK, then run snappyHexMesh. It may take some time to get your setup right, but snappy generates very good meshes when you get everything working. You won't need to use gmesh unless you want to.
Good luck,
Alan
Good luck,
AlanR is offline   Reply With Quote
Old   June 24, 2010, 03:28
Silvia Di Francesco
Hi Alan , thank you for your suggestions.
I did'nt realize that snappy hex requires 3D geometry.....
By now I extend the 2D geometry to obtain a 3D stl file.
This is the resulting mesh I obtained (pdf file...).
I notice that changing the refinement level the results do not change very much.
Do you think is it possible to refine mesh in order not to have a discontinuous surface?
PS: This is the blockmesh file i used:
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(-120 0 0)//0
(280 0 0)//1
(280 85 0)
(-120 85 0)//3
(-120 0 40)
(280 0 40)//5
(280 85 40)
(-120 85 40)//7
blocks
hex (0 1 2 3 4 5 6 7) (80 20 8) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 7 3)
patch outlet
(1 5 6 2)
wall bottom
(0 4 5 1)
patch atmosphere
(3 7 6 2)
patch rightwall
(4 5 6 7))
patch leftwall
(0 1 2 3))
mergePatchPairs
Old   June 25, 2010, 01:40
Alan Russell
Sylvia,
Your blockMeshDict looks good. 2D or 3D is up to you, snappy will do either one. I thought it sounded like a 3D problem. If you do 2D, you need to have empty front and back patches in your blockMesh. I used the Coral.stl file you sent in the first message and got the snapping to work. Here's the snappyHexMeshDict file I used - I commented out the refinement box in two places, changed the level to (4 4), in mesh controls changed min volume to 1e-3 and min vol ratio to 0.1. You will need to adjust the blockMesh to fit the stl, but this snappyHexMeshDict should work.
Once you have something reasonable, experiment with the size of the cells in blockMesh, making them smaller to refine the overall mesh. The level control will refine the mesh toward the surface. Hope this works for you,
Alan
FoamFile
version 2.0;
format ascii;
class dictionary;
snap true;
addLayers true;
geometry
coral.stl
name coral;
/* refinementBox
type searchableBox;
min (64 0 0);
max (96 22 40);
// refinement.
features
// level 2;
refinementSurfaces
coral
level (4 4);
// three modes
refinementRegions
/* refinementBox
mode inside;
levels ((1E15 4));
// Mesh selection
locationInMesh (80 23 0.5);
snapControls
// to surface
nSmoothPatch 5;
tolerance 3.0;
nSolveIter 30;
nRelaxIter 5;
addLayersControls
relativeSizes true;
layers
coral_bottom
nSurfaceLayers 1;
expansionRatio 1.0;
// is the
minThickness 0.1;
nGrow 1;
featureAngle 30;
nRelaxIter 3;
nSmoothNormals 3;
nLayerIter 50;
// where to undo.
meshQualityControls
maxNonOrtho 65;
maxConcave 80;
minFlatness 0.5;
minVol 1e-3;
minArea -1;
minTwist 0.02;
minFaceWeight 0.02;
minVolRatio 0.1;
// Advanced
nSmoothScale 4;
// Advanced
debug 0;
Old   June 28, 2010, 05:16
Silvia Di Francesco
Thanks Alan.
The strange thing is that the visualization using only parafoam and using foamtoVTK command is different.
Changing to VTK the mesh looks pretty good....
Now could you help me setting the boundary conditions?
I'd like to have a dominion with an outlet condition free and an inlet condition with a velocity changing along the vertical.
As I said I'd like to use the interFoam solver, or do you think that another solver is better?
Old   June 30, 2010, 13:50
Alan Russell
Silvia,
I suggest looking at the pitzDailyExptInlet tutorial to see how inlet profiles work. The tutorial boundary conditions should work well for your model. I haven't used interFoam - it's designed to model two incompressible fluids and the interface between them, like in the dam break tutorial. If you want to model water flow over an object, simpleFoam should work. If the water/air interface is important, then you need interFoam. Searching this forum is a good way to find answers - someone has probably set up a model similar to yours.
Alan
[snappyHexMesh] Find some gap between surfaces using SnappyHexMesh Linxiangfeng OpenFOAM Meshing & Mesh Conversion 0 January 14, 2017 22:27
[snappyHexMesh] MultiRegionMeshing with SnappyHexMesh - SplitMeshRegions doesnt pickup my surfaces Kenneth J. OpenFOAM Meshing & Mesh Conversion 0 January 30, 2015 10:07
[snappyHexMesh] SnappyHexMesh segmentation Fault nithishgupta OpenFOAM Meshing & Mesh Conversion 1 December 18, 2014 04:03
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) Irish09 OpenFOAM Meshing & Mesh Conversion 23 July 15, 2013 07:45
[snappyHexMesh] SnappyHexMesh and 2 Phase Modelling alexm OpenFOAM Meshing & Mesh Conversion 19 June 18, 2009 18:07
