[blockMesh] Block with cylinder - BC on a round spot on a surface.
Old   April 12, 2011, 10:40
Default Block with cylinder - BC on a round spot on a surface.
lindstroem is on a distinguished road
Hi Everybody!
I want to run a simulation where i want to specify certain boundary conditions on a small spot on one surface - different to the rest of this surface. Therefore i created the attached mesh.
First of all I get a common error "Number of edges not aligned with or perpendicular to non-empty directions". It has to be some edges on the outer rim of the spot, I dont know how to fix it. I also attached the blockMeshDict. Thanks for all suggestions concerning this problem.
In general: Of course I will run some mesh refinements later on, but has anyone experience with similar meshes and maybe some advices? As said, my aim is to specify a individual BC on the round spot. Maybe someone has a complete different idea?
Thanks in advance!
lindstroem is offline   Reply With Quote
Old   April 12, 2011, 11:54
Martin
MartinB will become famous soon enough
you should define some additional blocks. Your block number 10 (counting starts at 0) should be divided into 4 blocks, your block number 0 into 2 blocks. Otherwise the blocks do not match to each other (see orange faces in Paraview screenshot). The non aligned edges should disappear afterwards.
As an alternative you can use mergePatchPairs to merge these blocks, but this might result in non hex elements on the merging faces.
Run checkMesh with additional options
checkMesh -allTopology -allGeometry
since this will give you more warnings and hints.
Martin
MartinB is offline   Reply With Quote
Old   April 13, 2011, 04:24
Hi Martin,
thank you very much for your help. I don't get the error any longer. I thought the mesh is important, if it fits, I don't have to care about the blocks. Now, I know it better.
And your right, I prefer not to merge the blocks.
Thank you!
[waves2Foam] What should lref and Aref be for surface piercing cylinder in waves?? arieljeds OpenFOAM Community Contributions 10 February 21, 2017 16:21
Circular cylinder surface shear stress Hqjen STAR-CCM+ 0 April 21, 2016 11:13
[ICEM] Tagging Faces of block or converting faces of block into surface AshwaniAssam ANSYS Meshing & Geometry 1 October 19, 2013 14:49
refine mesh inside a block, water surface not smooth anymore JohnAB STAR-CCM+ 2 October 4, 2013 13:53
enGrid right tool for surface mesh -> cylinder? mankoff enGrid 1 February 24, 2013 15:54
