[Salome] Structured mesh and boundary layer with Salome
Old   July 21, 2011, 10:25
Default Structured mesh and boundary layer with Salome
Robin
wwrfd is on a distinguished road
Hi everyone,
I'm supposed to make a study on cylindrical shapes using Salome openFOAM coupling.
Problem is I want to make a structured mesh with boundary layers on it. I saw some threads talking about that, but there weren't making any reference to my problem. I understood the process to refine the mesh near the BC walls (I attached some pictures) but my geometry is made of several cylinders crossing each others and I had to use the boolean operation "fuse" to have only one solid that make the fluid volume.
At the intersections of the cylinders, the algorithm of quadrangle mapping doesn't work because I don't have 4 edges (which is logical unfortunatly...) so I wondered if there were a way to project the faces or to do a sketch on the main cylinder (the horizontal one) of the others cylinders to have 4 edges per face instead of using the boolean operation fuse that creates meshing problem (for structured mesh).
I hope I explained it the right way so everybody can understand the problem.
I attached some pictures of my geometry and a structured mesh with a "pseudo" boundary layer I managed to create on a simple cylinder.
Thank you for your replies.
wwrfd is offline   Reply With Quote
Old   December 17, 2011, 01:33
vasanth kumar chuttu
vasanthkch is on a distinguished road
Originally Posted by wwrfd View Post
Hi everyone,
Attachment 8495
Attachment 8496
Attachment 8497
Attachment 8498
hi,
i am doing flow inside a cylinder i have a question how did u mesh that cylinder can please help me im facing problem that is base for my project i am new to this openFoam
vasanthkch is offline   Reply With Quote
Old   December 21, 2011, 05:46
Robin
Originally Posted by vasanthkch View Post
hi,
Hi, do you also use Salome to mesh the cylinder? Otherwise I would advice you to use Salome only to export the geometry in STL. file, so you can mesh it with SnappyHexMesh, there are excellent tutorials for meshing a cylinder with it, moreover, when I started my project the version 2.0 of openFOAM wasn't released yet, but the last update SnappyHexMesh has been improved and I think it will be perfect for your projet. You have several tutorials to use SnappyHexMesh, may I suggest you to refer to this one: http://openfoamfoorumi.com/wordpress...inenAaltoU.pdf
You can also refer to this thread for snappyHexmesh:
http://www.cfd-online.com/Forums/ope...ture-edge.html
If you really want to do the meshing part with salome, I can write you a small tutorial with screen captures to show you how to do it.
Good luck for your project.
Regards.
Old   February 21, 2012, 04:01
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Can you made it or post a link to any information around this theme?
Thank you.
j-avdeev is offline   Reply With Quote
Old   April 4, 2012, 03:06
kid
cfdkid
kid is on a distinguished road
Hello Robin,
Need structured mesh for NACA0012 airfoil. Salome was used to create un-structured mesh, but for airfoil one required structured mesh for capturing boundary layer.
Can you guide me on how to generate structured mesh in Salome? (not snappyHexMesh)
Regards,
CFDkid
kid is offline   Reply With Quote
Old   September 4, 2014, 09:48
ok
Maimouna is on a distinguished road
[QUOTE=
Regards.[/QUOTE]
Dear Robin,
could you guide me please to mesh flow around circular cylinder using Salome. If you still have that tutorial with screen capture, it would be really grateful to help me please. Or any other tutorial could help me.
Kind regards
Maimouna is offline   Reply With Quote
Old   September 4, 2014, 12:49
Default Tutorial
Robin
Very old threat, I assume it's still difficult to generate a structured mesh even with the latest release of Salome? I haven't used it for almost 2 years but I remember how I did it ( I think).
For a cylinder shape it is very easy, you just define a circle split into as much vertices as you want as long as you define 4 edges per surface (to ensure strutured mesh). For this example I just designed a square, and then add vertices at a 45 deg angle and a fixed distance from the center of the square. From that I generated 5 surfaces, used the merging operation (boolean operation) put the same number of elements on vertices to ensure a structured mesh (bijection). Once you get that, you extrud your mesh in one of the axis of your cylinder.
I may check that if I have time to play with it to see what it is, but they made really good improvement so far compared to when I used to use it. I'll upload a short presentation that explains the step that I did at that time. For any complex shapes, I don't really recommend salome if you're doing CFD analysis and need a structured mesh, have you tried Gmsh?
Kind regards.
Robin
Old   September 5, 2014, 06:31
ok
Dear Robin,
lots of thanks for your help. I just installed Salome yesterday, I'm still not familiar with it.
If you could try and do the small presentation for that, it would be really grateful.
I myself would like to use Gmesh, but I'm still learning it. If you have such tutorials would help me, I would be really grateful.
Best regards
Maimouna
Old   March 7, 2022, 17:27
jose daniel
hoyos98 is on a distinguished road
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
hoyos98 is offline   Reply With Quote
boundary layer, cylindrical, openfoam 1.7.1, salome, structured mesh
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
