[snappyHexMesh] Extract one face of a sHM-mesh |
December 31, 2010, 17:29 |
Marko Josic
Rep Power: 15 |
Hallo
i use openFoam to calculate drag and lift from airfoils which were created in Matlab. Is there any way to extract a face/patch of a sHM-mesh? Because the sHM can generate an fine grid with boundarylayer, but i need only a 2D mesh. So I would extract a face and extrude it to a "3d"-mesh with "empty"-boundaries. It would save a lot resources, and time. Any suggestions? Thanks, a lot! Last edited by emjay; January 1, 2011 at 08:05. Reason: specify |
January 5, 2012, 06:03 |
Nick
Rep Power: 14 |
Check this link:
http://www.cfd-online.com/Forums/ope...tml#post281498 For OF 1.7 it should work, but I have not been able to run it in OF 2.01. |
airfoil shm 2d |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 14:18 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Missing face error from FLUENT even after repairing mesh + other questions | unknown159 | ANSYS Meshing & Geometry | 0 | July 5, 2013 20:18 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
