[Other] error: faces are incorrectly oriented |
September 2, 2016, 10:32 |
Sergio
Rep Power: 9 |
Hi all.
I made a Venturi tube jointed with a small cylinder but when ran checkMesh got the following error: Overall domain bounding box (0 -0.016 -0.016) (0.182 0.016 0.016) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (7.20866e-20 -2.52969e-15 -6.29467e-15) OK. Max cell openness = 3.75848e-16 OK. Max aspect ratio = 189.126 OK. Minimum face area = 4.86213e-12. Maximum face area = 1.39607e-06. Face area magnitudes OK. Min volume = 1.55748e-14. Max volume = 7.9738e-10. Total volume = 0.000108002. Cell volumes OK. Mesh non-orthogonality Max: 88.6327 average: 22.3043 *Number of severely non-orthogonal (> 70 degrees) faces: 19911. Non-orthogonality check OK. <<Writing 19911 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 10 faces are incorrectly oriented. <<Writing 10 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 4.47115, 2 highly skew faces detected which may impair the quality of the results <<Writing 2 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 2 mesh checks. I read that this error occurs due to an incorrect order in points or blocks so I changed the order and didn't work. This is my mesh: vertices ( (0 0 16) // 0 (0 16 0) // 1 (0 0 -16) // 2 (0 -16 0) // 3 (40 0 16) // 4 (40 16 0) // 5 (40 0 -16) // 6 (40 -16 0) // 7 (60.840712 0 8) // 8 (60.840712 8 0) // 9 (60.840712 0 -8) // 10 (60.840712 -8 0) // 11 (76.840712 0 8) // 12 (76.840712 8 0) // 13 (76.840712 0 -8) // 14 (76.840712 -8 0) // 15 (141.995484 0 16) // 16 (141.995484 16 0) // 17 (141.995484 0 -16) // 18 (141.995484 -16 0) // 19 (182 0 16) // 20 (182 16 0) // 21 (182 0 -16) // 22 (182 -16 0) // 23 (65.840712 8 0) // 24 (68.840712 7.416198487 3) // 25 (71.840712 8 0) // 26 (68.840712 7.416198487 -3) // 27 (65.840712 12 0) // 28 (68.840712 12 3) // 29 (71.840712 12 0) // 30 (68.840712 12 -3) // 31 ); blocks ( hex (0 3 2 1 4 7 6 5) (60 40 40) simpleGrading (1 1 1) hex (4 7 6 5 8 11 10 9) (60 40 40) simpleGrading (1 1 1) hex (8 11 10 9 12 15 14 13) (60 40 40) simpleGrading (1 1 1) hex (12 15 14 13 16 19 18 17) (60 40 40) simpleGrading (1 1 1) hex (16 19 18 17 20 23 22 21) (60 40 40) simpleGrading (1 1 1) hex (28 31 30 29 24 27 26 25) (60 40 40) simpleGrading (1 1 1) ); edges ( arc 0 1 (0 11.3137085 11.3137085) arc 1 2 (0 11.3137085 -11.3137085) arc 2 3 (0 -11.3137085 -11.3137085) arc 3 0 (0 -11.3137085 11.3137085) arc 4 5 (40 11.3137085 11.3137085) arc 5 6 (40 11.3137085 -11.3137085) arc 6 7 (40 -11.3137085 -11.3137085) arc 7 4 (40 -11.3137085 11.3137085) arc 8 9 (60.840712 5.656854 5.656854) arc 9 10 (60.840712 5.656854 -5.656854) arc 10 11 (60.840712 -5.656854 -5.656854) arc 11 8 (60.840712 -5.656854 5.656854) arc 12 13 (76.840712 5.656854 5.656854) arc 13 14 (76.840712 5.656854 -5.656854) arc 14 15 (76.840712 -5.656854 -5.656854) arc 15 12 (76.840712 -5.656854 5.656854) arc 16 17 (141.995484 11.3137085 11.3137085) arc 17 18 (141.995484 11.3137085 -11.3137085) arc 18 19 (141.995484 -11.3137085 -11.3137085) arc 19 16 (141.995484 -11.3137085 11.3137085) arc 20 21 (182 11.3137085 11.3137085) arc 21 22 (182 11.3137085 -11.3137085) arc 22 23 (182 -11.3137085 -11.3137085) arc 23 20 (182 -11.3137085 11.3137085) arc 24 25 (66.719392 8 2.121320) arc 25 26 (70.962032 8 2.121320) arc 26 27 (70.962032 8 -2.121320) arc 27 24 (66.719392 8 -2.121320) arc 28 29 (66.719392 12 2.121320) arc 29 30 (70.962032 12 2.121320) arc 30 31 (70.962032 12 -2.121320) arc 31 28 (66.719392 12 -2.121320) ); boundary ( inlet { type patch; faces ( (0 3 2 1) ); } outlet { type patch; faces ( (20 23 22 21) ); } rightup { type wall; faces ( (0 1 5 4) (4 5 9 8) (12 13 17 16) (16 17 21 20) ); } leftup { type wall; faces ( (1 2 6 5) (5 6 10 9) (13 14 18 17) (17 18 22 21) ); } rightdown { type wall; faces ( (0 3 7 4) (4 7 11 8) (8 11 15 12) (12 15 19 16) (16 19 23 20) ); } leftdown { type wall; faces ( (2 3 7 6) (6 7 11 10) (10 11 15 14) (14 15 19 18) (18 19 23 22) ); } atmosfera { type patch; faces ( (28 31 30 29) ); } smallcylinder { type wall; faces ( (24 25 29 28) (25 26 30 29) (26 27 31 30) (27 24 28 31) ); } masterPatch { type patch; faces ( (24 27 26 25) ); } slavePatch { type wall; faces ( (8 9 13 12) (9 10 14 13) ); } ); mergePatchPairs ( (masterPatch slavePatch) ); Can someone tell me where is the error? Thanks in advantage. |
September 9, 2016, 10:36 |
Sergio
Rep Power: 9 |
Hi all.
I could run my case, changed the way of doing the cylinders and run correctly. Thanks. |
[Commercial meshers] non-orthogonality errors, incorrectly oriented faces | cfdmarkus | OpenFOAM Meshing & Mesh Conversion | 13 | September 20, 2019 05:05 |
Faces incorrectly oriented DURING the simulation | Giuseppe23 | OpenFOAM | 0 | March 9, 2015 13:14 |
[blockMesh] Problem with "faces are incorrectly oriented" | The_Architect | OpenFOAM Meshing & Mesh Conversion | 2 | January 31, 2013 05:50 |
How to avoid the generations of incorrectly oriented faces when morphing mesh | fumiya | OpenFOAM | 0 | October 21, 2012 23:16 |
Wrong oriented faces due to opposite face bends? | Arnoldinho | OpenFOAM | 5 | August 16, 2012 05:00 |
