[snappyHexMesh] snap stage generates internal triangles |
May 20, 2016, 15:03 |
Rep Power: 11 |
Hi, during the snap stage the snappyHexMesh generates illegal internal triangles (see attached images for comparison of original STL geometry and mesh generated by snappyHexMesh). The STL was checked with surfaceCheck, the log is the following:
triSurface$ surfaceCheck -checkSelfIntersection aneurysm.stl Reading surface from "aneurysm.stl" ... Statistics: Triangles : 7462 Vertices : 3733 Bounding Box : (-8.17053 -9.95681 -3.16317) (9.29674 5.487 18.3778) Region Size ------ ---- patch0 7462 Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 0 0.05 .. 0.1 : 0 0.1 .. 0.15 : 0 0.15 .. 0.2 : 0 0.2 .. 0.25 : 0 0.25 .. 0.3 : 0 0.3 .. 0.35 : 0 0.35 .. 0.4 : 0 0.4 .. 0.45 : 0.000402037 0.45 .. 0.5 : 0.000268025 0.5 .. 0.55 : 0.0010721 0.55 .. 0.6 : 0.00160815 0.6 .. 0.65 : 0.00254623 0.65 .. 0.7 : 0.0032163 0.7 .. 0.75 : 0.00402037 0.75 .. 0.8 : 0.00522648 0.8 .. 0.85 : 0.0087108 0.85 .. 0.9 : 0.0305548 0.9 .. 0.95 : 0.118467 0.95 .. 1 : 0.823908 min 0.409765 for triangle 7461 max 0.999999 for triangle 6093 Edges: min 0.116441 for edge 2482 points (6.99224 0.323031 -1.78307)(6.89283 0.373643 -1.81644) max 0.771082 for edge 5440 points (-6.57135 -9.32061 1.086)(-6.66217 -9.95464 1.51533) Checking for points less than 1e-6 of bounding box ((17.4673 15.4438 21.541) metre) apart. Found 0 nearby points. Surface is closed. All edges connected to two faces. Number of unconnected parts : 1 Number of zones (connected area with consistent normal) : 1 Checking self-intersection. Surface is not self-intersecting End Maybe someone knows how to solve this problem ? |
[snappyHexMesh] problems with sHM: it doesn't snap! | Claudio87 | OpenFOAM Meshing & Mesh Conversion | 25 | July 10, 2020 08:06 |
[openFuelCell] DecomposePar generates internal holes | Swagga5aur | OpenFOAM Community Contributions | 6 | December 25, 2018 10:12 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] snappyHexMesh. irregular cells on snap stage | Svensen | OpenFOAM Meshing & Mesh Conversion | 0 | April 3, 2015 03:12 |
[snappyHexMesh] Snap generates holes in the mesh | Svensen | OpenFOAM Meshing & Mesh Conversion | 0 | March 25, 2015 03:20 |
