[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue?
Old   March 1, 2015, 09:13
Default snappyhexmesh doesn't creat mesh in parallel issue?
Klaus
klausb will become famous soon enough
I'd like to speedup meshing with snappyhexmesh. Everything works fine, when I run it on one core but my i7 offers "8" so let's make use of them.
I had a look at the motorbike case, used the decomposepardict... there are no errors but snappyhexmesh doesn't create a mesh.
Where's the error?
This is my Allmesh script:
#!/bin/sh
# Determine OpenFOAM version
OF_MAJOR=`echo $WM_PROJECT_VERSION | cut -d'.' -f1`
OF_MINOR=`echo $WM_PROJECT_VERSION | cut -d'.' -f2`
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Set variable to distinguish between OF 2.2 and older versions
if [ $OF_MAJOR -le 2 -a $OF_MINOR -le 1 ]; then
OLD=1
else
OLD=0
fi
## Make 3D mesh in slab of cells.
cd airfoil_snappyHexMesh
runApplication blockMesh > output/1-blockMesh.log 2>&1
if [ $OLD -eq "1" ]; then
runApplication surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/airfoil.stl airfoil > output/2-surfaceFeatureExtract.log 2>&1
else
runApplication surfaceFeatureExtract > output/2-surfaceFeatureExtract.log 2>&1
fi
# THIS WORKS
# running snappyhexmesh on one core of the i7 processor
#runApplication snappyHexMesh -overwrite > output/3-snappyHexMesh.log 2>&1
#rm -f 0/*
# THIS DOESN'T WORK
# running snappyhexmesh on 8 cores of the i7 processor
runApplication decomposePar
runParallel snappyHexMesh 8 -overwrite > output/3-snappyHexMesh.log 2>&1
rm -f 0/*
runApplication reconstructParMesh -constant
This is my decomposepardict:
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object decomposeParDict;
numberOfSubdomains 8;
method hierarchical;
//method ptscotch;
simpleCoeffs
n (4 2 1);
delta 0.001;
hierarchicalCoeffs
n (4 2 1);
delta 0.001;
order xyz;
manualCoeffs
dataFile "cellDecomposition";
klausb is offline   Reply With Quote
Old   March 7, 2015, 11:55
Pascal Balz
pbalz is on a distinguished road
Hi Klaus,
if your problem is still present, try the following code:
foamJob -parallel -screen snappyHexMesh
reconstructParMesh -latestTime
This works fine for me.
pbalz is offline   Reply With Quote
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Issue with arbitrary Lagrangian-Eulerian method and mesh optimization mikolchon Main CFD Forum 0 August 16, 2014 15:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
