[Commercial meshers] STAR CCM+ mesh to Foam in OpenFoam 2.4 |
December 17, 2015, 02:57 |
Gajendra Gulgulia
Rep Power: 13 |
Hello all,
I am a new user of OpenFoam. I am practicing with OpenFOAM V 2.4 . When am trying to convert a STAR CCM Mesh to FOAM Mesh using the following command: # $ ccm26ToFoam mesh_name.ccm i am getting the following error saying command not found. is this command not supported on Foam 2.4 ? Replies/suggestions appreciated |
December 17, 2015, 03:39 |
W.T
Rep Power: 13 |
As far I know ccm26ToFoam depends on ibccmio which is properitary and it's not build by default. You should compile ibccmio and ccm26ToFoam.
This information can be found in readme file for ThirdPart packages https://github.com/OpenFOAM/ThirdPar...ter/README.org |
December 18, 2015, 00:59 |
Gajendra Gulgulia
Rep Power: 13 |
hello Dybuk,
Thanks a lot for the suggestion, was very helpful |
December 19, 2015, 13:18 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: http://openfoamwiki.net/index.php/Ccm26ToFoam
February 2, 2017, 07:46 |
Ricky
Rep Power: 11 |
hello all,
I have one question, is there any way to mapFields from star-ccm to OpenFOAM, something like fluentDataToFoam? (i.e., converting the star-ccm data to OpenFOAM readable data first) I have some simulation results in star-ccm, which I want to use as my initial condition in OpenFOAM. It would really save me a lot of time, if I avoid re-simulating those cases again in OpenFOAM. Any help is really appreciated. Regards, Ricky |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
