December 31, 2015, 11:33 |
Import fields to new mesh
Hello everyone !
I am currently running a simulation using the rhoCentralFoam solver and everything is going relatively well. The problem is that there are areas of my mesh I would like to refine by, for example, changing the number of cells of some of the hexaedras of my blockMeshDict, but WITHOUT having to restart my sim from 0 (and lose the dozens of hours of computing time I used). So basically, make a "new" mesh from the same geometry but keep the existing solution solution from the "old" mesh. Is it possible ? If so, how ? Thank you for your help! |
January 1, 2016, 08:38 |
Paulo Vatavuk
Rep Power: 17 |
Hi DGW,
You can use the mapFields utility as described in item 2.1.5 of the User Guide. Happy New Year! Paulo |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
