[snappyHexMesh] snappyHexMesh can't create a fine Mesh from stl from Rhinoceros |
April 23, 2017, 05:13 |
Pouria Taghikhani
Rep Power: 9 |
Hi Foamers,
I am trying to simulate a propeller witch I created in propCad 2005 software. There is no problem in Rhino, when importing the point cloud from propCad, But when I export it as STL and run snappyHexMesh command, the edges go crazy. please Help me if you can. BadMesh.png |
April 24, 2017, 03:41 |
Anton Kidess
Rep Power: 29 |
You need to refine your mesh much stronger at the edges, and best also use explicit feature refinement.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
April 25, 2017, 05:41 |
Kal-El
Rep Power: 9 |
I had similar problems when I was using too coarse mesh. It's easy to fix.
April 25, 2017, 06:57 |
Pouria Taghikhani
Rep Power: 9 |
the problem is that when using a finer mesh, solution will diverge. no matter how small is the time step.
April 25, 2017, 07:01 |
Kal-El
Rep Power: 9 |
April 25, 2017, 08:59 |
Pouria Taghikhani
Rep Power: 9 |
All is set on 5
April 25, 2017, 12:35 |
Try to check your starting surface with surfaceCheckMesh utility.
Does it pass all Checks? SHM needs at least three cells between surface, to define properly surfaces. as already suggested maybe you have to increase refinement on edges. |
April 26, 2017, 05:53 |
Pouria Taghikhani
Rep Power: 9 |
This is the results of surfaceCheck command:
Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 0.0273287 0.05 .. 0.1 : 0.034305 0.1 .. 0.15 : 0.0312111 0.15 .. 0.2 : 0.0223543 0.2 .. 0.25 : 0.0189269 0.25 .. 0.3 : 0.0315751 0.3 .. 0.35 : 0.0126786 0.35 .. 0.4 : 0.0175923 0.4 .. 0.45 : 0.0399769 0.45 .. 0.5 : 0.0435257 0.5 .. 0.55 : 0.0263884 0.55 .. 0.6 : 0.0207164 0.6 .. 0.65 : 0.0407049 0.65 .. 0.7 : 0.0490157 0.7 .. 0.75 : 0.0532015 0.75 .. 0.8 : 0.0782857 0.8 .. 0.85 : 0.071825 0.85 .. 0.9 : 0.10428 0.9 .. 0.95 : 0.13361 0.95 .. 1 : 0.142497 min 2.4095e-006 for triangle 17056 max 0.999962 for triangle 15498 Edges: min 2.72822e-005 for edge 2343 points (-0.00077024 -0.0368108 0.000154718)(-0.000764351 -0.0368108 0.000181357) max 0.0503 for edge 8803 points (-0.02515 0.0068669 -1.57673e-006)(0.02515 0.0068669 -1.57673e-006) Checking for points less than 1e-6 of bounding box ((0.176563 0.0926035 0.177137) metre) apart. close unconnected points 2970 (2.46516e-012 0.0068669 0.0251484) and 62 (3.30524e-012 0.0068669 0.0251484) distance:8.40085e-013 close unconnected points 2971 (2.46516e-012 0.0068669 -0.0251516) and 1568 (3.30525e-012 0.0068669 -0.0251516) distance:8.40087e-013 Found 2 nearby points. Surface is not closed since not all edges connected to two faces: connected to one face : 2113 connected to >2 faces : 148 Conflicting face labels:2609 Dumping conflicting face labels to "problemFaces" Paste this into the input for surfaceSubset Number of unconnected parts : 16 Splitting surface into parts ... Writing zoning to "zone_propellerTip.vtk"... writing part 0 size 6494 to "propellerTip_0.obj" writing part 1 size 129 to "propellerTip_1.obj" writing part 2 size 2317 to "propellerTip_2.obj" writing part 3 size 2849 to "propellerTip_3.obj" writing part 4 size 2849 to "propellerTip_4.obj" writing part 5 size 2317 to "propellerTip_5.obj" writing part 6 size 129 to "propellerTip_6.obj" writing part 7 size 2849 to "propellerTip_7.obj" writing part 8 size 2317 to "propellerTip_8.obj" writing part 9 size 129 to "propellerTip_9.obj" writing part 10 size 2849 to "propellerTip_10.obj" writing part 11 size 2317 to "propellerTip_11.obj" writing part 12 size 129 to "propellerTip_12.obj" writing part 13 size 2849 to "propellerTip_13.obj" writing part 14 size 2317 to "propellerTip_14.obj" writing part 15 size 129 to "propellerTip_15.obj" Number of zones (connected area with consistent normal) : 17 More than one normal orientation. Last edited by Taghi; May 5, 2017 at 02:40. |
April 26, 2017, 10:43 |
#9 |
Ok, one BIG issue is your stl.
It's better if you remesh it. Try to use Salome. Have a look to holzmanncfd.de for helping tutorials. Sent from my ASUS_X008D using CFD Online Forum mobile app |
April 26, 2017, 10:46 |
#10 |
May 4, 2017, 13:59 |
#11 |
Pouria Taghikhani
Rep Power: 9 |
I watched the video but there it didn't have any solutions to my problem.
anyway I rebuilt the surface and rechecked it: Code:
Region Size ------ ---- ascii 279654 Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 0.138596 0.05 .. 0.1 : 0.149109 0.1 .. 0.15 : 0.0963333 0.15 .. 0.2 : 0.0455706 0.2 .. 0.25 : 0.027838 0.25 .. 0.3 : 0.0164131 0.3 .. 0.35 : 0.0187339 0.35 .. 0.4 : 0.0126978 0.4 .. 0.45 : 0.0153011 0.45 .. 0.5 : 0.0176504 0.5 .. 0.55 : 0.02605 0.55 .. 0.6 : 0.0338132 0.6 .. 0.65 : 0.0647228 0.65 .. 0.7 : 0.103099 0.7 .. 0.75 : 0.0697612 0.75 .. 0.8 : 0.0498759 0.8 .. 0.85 : 0.0410042 0.85 .. 0.9 : 0.0329586 0.9 .. 0.95 : 0.0252598 0.95 .. 1 : 0.0152117 min 4.87625e-009 for triangle 169346 max 0.999602 for triangle 26076 Edges: min 1.24006e-007 for edge 105161 points (0.0371511 0.00866685 0.0803856)(0.0371511 0.00866673 0.0803856) max 0.0503 for edge 357 points (2.46515e-012 0.05575 -0.0251516)(2.46515e-012 0.05575 0.0251484) Checking for points less than 1e-6 of bounding box ((0.176562 0.0926035 0.177135) metre) apart. small edge between points 67691 (0.0174877 0.0539546 0.0868111) and 67690 (0.0174878 0.0539545 0.0868111) distance:2.18343e-007 small edge between points 125663 (-0.0771587 0.0539559 0.0434571) and 125662 (-0.0771586 0.0539557 0.0434572) distance:2.22179e-007 small edge between points 45716 (0.0879661 0.0539571 0.0101961) and 45715 (0.0879661 0.0539569 0.010196) distance:2.18811e-007 small edge between points 102814 (-0.0651727 0.0539574 -0.0599542) and 102813 (-0.0651728 0.0539573 -0.0599541) distance:2.17539e-007 small edge between points 102817 (-0.0651722 0.0539585 -0.0599548) and 102816 (-0.0651723 0.0539583 -0.0599547) distance:2.20831e-007 small edge between points 102819 (-0.0651718 0.0539592 -0.0599552) and 102818 (-0.0651719 0.053959 -0.0599551) distance:2.17539e-007 small edge between points 67698 (0.0174836 0.0539603 0.0868119) and 67697 (0.0174837 0.0539601 0.0868119) distance:2.18811e-007 small edge between points 67699 (0.0174835 0.0539604 0.086812) and 67698 (0.0174836 0.0539603 0.0868119) distance:2.22218e-007 small edge between points 125669 (-0.0771613 0.0539629 0.0434525) and 125668 (-0.0771612 0.0539627 0.0434526) distance:2.18049e-007 small edge between points 102832 (-0.0651686 0.0539655 -0.0599587) and 102831 (-0.0651687 0.0539654 -0.0599586) distance:2.19381e-007 small edge between points 102834 (-0.0651684 0.0539661 -0.0599589) and 102833 (-0.0651684 0.0539659 -0.0599589) distance:2.22147e-007 Found 11 nearby points. Surface is closed. All edges connected to two faces. Number of unconnected parts : 1 Number of zones (connected area with consistent normal) : 1 End Last edited by Taghi; May 5, 2017 at 02:39. |
May 4, 2017, 14:32 |
#12 |
Well, I'm not so pessimistic, before you had 17 unconnected regions, now you have one region.. there are not manifolds and you solved the normal orientation.
That's an encouraging step forward. Ok, maybe you have to change to MEfisto or Netgen 2D, the overall triangle quality is not so satisfying... About small edges i think you're trying to mesh very fine that area. Is it strictly necessary? I think you can increase your mesh refinement phase and use the featureEdge settings for it. Code:
edge.emesh level (...) To get it: Consider your initial cell dimension (background mesh) and divide by 3, that's the minimum dimension for each of the above cells that you have to obtain during castellated step. Then, measure your small distance into your geometry and divide it by 2^n where exponent n is the refinement level you have to use to have at least the minimum cell dimension, you choose n. Sent from my ASUS_X008D using CFD Online Forum mobile app |
May 4, 2017, 14:39 |
#13 |
In any case, consider that i face similar problem as yours recently and i was not able to solve it except for having a very big mesh size...millions and millions of cells...maybe others have other hints i don't know about...
May 4, 2017, 15:48 |
#14 |
Pouria Taghikhani
Rep Power: 9 |
Fantastic!
edge.emesh level (...) thank you so much. Last edited by Taghi; May 5, 2017 at 02:39. |
propeller meshing, rhino3d, snappyhexmesh |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? | keepfit | OpenFOAM | 4 | February 19, 2017 14:40 |
[snappyHexMesh] snappyHexMesh does not create mesh in body volume | Illmatic | OpenFOAM Meshing & Mesh Conversion | 1 | July 11, 2016 21:35 |
[snappyHexMesh] How to create internal boundaries using snappyHexMesh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 2 | October 19, 2014 09:57 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
